I don’t have code to share yet.
I was wondering if I setup my program at my house with the argon and xenon; if it will run without wifi at my relatives house. I want to make a pool controller and they have 1Mb internet. I am pretty sure it would be better to not rely on it at all.
My thought is I would program and test everything here, on my pool, then take it down there and let it run.
I appreciate any feedback.
Yes, if you change from the default mode. The easiest solution is to use:
SYSTEM_THREAD(ENABLED);
which allows your code to run even when there is no cloud connectivity. There are a few caveats, most importantly you should avoid calling Particle.publish when not cloud connected to avoid blocking for several minutes in certain cases.
10-4 Thanks. I had seen people talk about using SYSTEM_THREAD on here before. I get to become a little more familiar with it now.
Thanks A lot!
