Code causes solid cyan light
I am new to coding and am working on a weather project for school. Whenever I flash my code, the light becomes solid cyan and I have to flash tinker every time to fix it. I think it has to do with the coding because when I flash the codes that use IFTTT it just becomes unreachable. Can anyone show me what the issue is with my code?
#include <LiquidCrystal_I2C_Spark.h>
#include <neopixel.h>
 LiquidCrystal_I2C *lcd;
String Hightemp = "70";
String Lowtemp = "50";
String Ctemp = "60";
String command = "Cloudy";
SYSTEM_MODE(AUTOMATIC);
// Define colors (R, G, B)
#define PEACH 200,50,5
#define CYAN 10,150,70
#define PURPLE 180,3,180
#define BLUE 20,20,255
#define WHITE 255,255,255
#define GREEN 10,180,10
#define YELLOW 200,150,0
#define LIGHTBLUE 135,206,250
#define INDIGO 75,0,130
#define OFF 10,180,10
// IMPORTANT: Set pixel COUNT, PIN and TYPE
#define PIXEL_PIN D2
#define PIXEL_COUNT 15
#define PIXEL_TYPE WS2812B
Adafruit_NeoPixel strip = Adafruit_NeoPixel(PIXEL_COUNT, PIXEL_PIN, PIXEL_TYPE);
int i = 0;
int weather = 0;
lcd = new LiquidCrystal_I2C(0x27,16,1);
lcd->init();
lcd->backlight();
lcd->clear();
  // register the Particle function
  Particle.function("screen", LedAansturing);
  strip.begin();
  strip.show(); // Initialize all pixels to 'off'
lcd->setCursor(1,0);
lcd->print(Hightemp);
lcd->setCursor(5,0);
lcd->print(Ctemp);
lcd->setCursor(9,0);
lcd->print(Lowtemp);
  // weather functies
  if(weather == 1)
    // RAIN
    for(i=0; i < PIXEL_COUNT; i++) {
      strip.setPixelColor(i, INDIGO);
    strip.show();
 else if(weather == 2)
    // SNOW
      strip.setPixelColor(i, WHITE);
    strip.show();
 else if(weather == 3)
    // CLOUDY
      strip.setPixelColor(i, BLUE);
    strip.show();
  else if(weather == 4)
    // CLEAR
      strip.setPixelColor(i, YELLOW);
    strip.show();
 else if(weather == 5)
    // OFF
      strip.setPixelColor(i, GREEN);
    strip.show();
  else
      strip.setPixelColor(i, CYAN);
    strip.show();
// this function automagically shows up in IFTTT
int LedAansturing(String command1)
        int plusLoc = command1.indexOf('+');
    int ampLoc = command1.indexOf('&');
    int atLoc = command1.indexOf('@');
       if (plusLoc != -1)  //if we were able to find a '+' in the string
    String commandB = command1.substring(0, plusLoc);
    Hightemp = commandB;
   else  //otherwise, if we couldn't find a plus sign, set Hightemp to "N/A"
     Hightemp = "N/A";
       if (ampLoc != -1)  //if we were able to find a '+' in the string
    String commandC = command1.substring(plusLoc+1, ampLoc);
    Lowtemp = commandC;
     Lowtemp = "N/A";
      if (atLoc != -1)  //if we were able to find a '+' in the string
     Ctemp = command1.substring(ampLoc+1, atLoc);
    command = command1.substring(atLoc+1);
     command = "Cloudy";
  Serial.println("Weather update received");
  Serial.println(command);
  if(command == "Rain" || command == "Raining" || command == "Rain Shower" || command == "Thunderstorms" || command == "Light Rain")
    weather = 1;
 else if(command == "Light Snow" || command == "Snow" || command == "Snowing")
    weather = 2;
  else if(command == "Cloudy" || command == "Mostly Cloudy" || command == "Partly Cloudy" || command == "Fair")
    weather = 3;
  else if(command == "Clear" || command == "Clear Skies" || command == "Sunny")
    weather = 4;
  else
    weather = 5;
Do you have pull-up resistors on your I2C lines?
Do you see anything on your display?
What does it do when you comment out all that LCD stuff?
My other code for the LCD screen worked but now when I flash it causes the same problem. It is supposed to just take the temperature and display it onto the LCD and then display a certain light for the current weather.
@WeathR, first I noticed that the entire if() then() “tree” in loop() could be reduced to a switch() statement where a color variable would be set. Then you would just need a single for()... strip.show() statement. Also, you don’t reset weather to zero so you will constantly call the color setting code in each loop. The same applies with your LCD code. I suggest you do some checks and only write things out if values have changed.
Also, the LedAansturing() function uses a LOT of String statements which will lead to heap fragmentation and eventual crashing. I suggest you change to c-string commands as much as possible.
As your code stands, does LedAansturing() Serial.print() the values you expect?
Ok thanks. Turns out it was because the 2 libraries don’t work well together.
