Cloud Connectivity Issues
It looks like there are some cloud connectivity issues. I have three particle devices ( 2x Boron and 1X Argon) unable to connect to the cloud. Flashes cyan and yellow. Anyone else having this issue?
Hey there,
For future reference, if you’re curious as to the state of the Particle services, you may always refer to https://status.particle.io/ for system-wide issues.
Which devices are flashing cyan, and which yellow? Yellow implies it is in DFU mode, which it should not default to at startup.
Thanks @DJ_Volt
I did look at that but the LED pattern was two rapid cyan flashes followed by one DFU yellow. It just continued to cycle through that pattern continuously.
