Hi, guy, I just encounter a wield problem. Just one hour ago, the cloud IDE could compile my code and upload the latest firmware to my core, but all of a sudden I found the latest firmware is not working properly like before, I checked out everything, found the circuit and firmware code are all good, I suspect the firmware uploaded to my core is not the one I expect. So i tried a test, that I compile the example code LED on the IDE, which allows D7 to on and off, since a led is linked to D7, so it could be simply observed. and I uploaded the firmware to the core, it was uploaded successfully, but on-board LED linked to D7 is not on. Anything wrong with the cloud compilation ?
Related topics
Topic | Replies | Views | Activity | |
Error: Could not compile. Please review your code. ---Even for example code--- | 8 | 3276 | November 21, 2015 | |
Download Firmware Binary (?! :-) | 20 | 6948 | August 6, 2014 | |
[SOLVED] I am receiving wrong firmware from Particle Dev | 5 | 1132 | December 17, 2015 | |
Cloud Compiler::: Error: Could not compile. Please review your code | 6 | 1384 | November 10, 2016 | |
What version of the firmware is the cloud IDE using? [SOLVED] | 4 | 1705 | December 13, 2018 |
