CLI gone awry for no apparent reason
My CLI has seeming gone awry and I don’t recall doing anything that would fuss it up. When I do something as simple as a particle list I get the following:
I’ve tried reinstalling the CLI with the following command: sudo npm install -g particle-cli but without help.
Thoughts?
(I’m running Mac 10.13.3 and have not had any CLI issues for the past year)
[update] I tried doing a reinstall with sudo and got the following:
This usually works for me:
sudo npm uninstall -g --unsafe-perm particle-cli
sudo npm install -g --unsafe-perm particle-cli
You DA Man!!!
So…the only remaining question is…why did this happen?
Regardless, I very much appreciate your help!
happened to me proceeding my enabling my github account for two factor authentication.
unintended consequences!
This happens to me a lot. You installed something else that needed and installed a different version of npm or node and that messed up your Particle install.
