Check for a particular Time to fire an event
I am looking for the best way to trigger an event at a particular time of day or even at a particular day. Say every Monday at 8pm. Is there a preferred way to do this?
My thoughts are with Time.day() == the day I want to fire, Time.hour() == etc…
I think @BulldogLowell has had a library for that and there also is this
https://build.particle.io/libs/TimeAlarms/0.0.3/tab/example/TimeAlarmsExample.ino
@frlobo, as @scruff mentioned have a look at Timer2 in this example:
@ScruffR, I’m in the process of completely refactoring this lib to use start/end callbacks. the original was just me converting my original from Arduino, I’ve re-shaped its use.
The Arduino is already updated, I still need to finish some simple constructors, refactor for Particle’s time library and put into new library format.
You could use IFTTT to ping your device using the date&time module. That’s an extra service to configure, but then you can easily update the timing if necessary without modifying your firmware.
Thank you everyone for your help!
@BulldogLowell will give it a shot! Thanks
