How would I schedule events eg turn on/off a relay at specific times
Firstly, not sure if this is the correct category, sorry in advance if it is not right.
I have a Photon connected to a relay that can control my boiler in my home. I control it via a small web app I wrote which uses javascript to call the API to run the exposed functions and return the status.
Works like a charm.
My next task is to implement a timer, for example for it to turn on at a specific time and off at another time.
I was originally thinking of controlling cron jobs on the website but it sounds like a hack n slash!
How would I achieve this in a sensible manor? I can’t seem to think of a solution
Thank you
you could use a library like this:
Excellent, I will have a look once I get home, just leaving work now
Morning,
would it be possible to do an array of DailyTimer objects? I would like some flexibility in the number of timed events
I suppose, but you are limited (right now) by by your choice of constructor. So you have to initialize the array of DailyTimer objects… something like this:
DailyTimer myTimer[] = {{8, 15, 13, 15, WEEKENDS},{9, 15, 22, 0, WEEKDAYS}};
We could certainly add a constructor that takes no arguments and uses come default values, but you eventually have to set the times anyways, I suppose.
I was thinking something like this process
[web]
Create list of events (stored in a database, sqlite3 probably)
save and push number of events to photon
[photon]
on push from web: initialise array of X number timers and pull details of each timer from web server and process
Yeah easily done. I am using these timers to do something like that… updating on or off times from time to time with web-hooks. For instance, I use Solar noon to determine when to open/close blinds on the east and west side of my house and sunset/sunrise for lawn watering and exterior lighting.
