I am using VS code under windows 10 and the particle workbench to devlop firmware for the Boron. However, I can only do “cloud compile” and “cloud flash” at the moment, because when I choose “install toolchain” in the particle workbench within VS code, it just installs that toolchain to my windows user folder (without asking if I would like to use a different directory), which unfortunately is SPACE , and the local particle toolchain doesn’t work with spaces in the path.
Is there a way to fix this?
