Hello,
I am having trouble with an AT command which doesn’t send me 2 response,
“AT+CEREG?” just show me “OK” and not the information that I want.
This is the information that it’s normally showing:
+CEREG: <n>,<stat>[,[<tac>],[<ci>],
[<AcT>[,[<cause_type>],[<reject_
cause>][,[<Assigned_Active_Time>,
[<Assigned_Periodic_TAU>]]]]]]
on the other hand, response like AT+CCID show me the good output.
It’s not possible to get the results of AT+CEREG? on Gen 3 devices including the Boron.
The reason is that the response is a URC (unsolicited result code), and URCs are not passed to the Cellular.command response handler on Gen 3 devices. It’s possible to register a URC handler, but not from user firmware, so essentially you can’t get the response.
Hi
Is it possible that you can give an example of how to register a URC handler?
Best Regards
