I’m trying to run a program that tracks a circuit and marks every time the current is above the baseline, but for some reason the SD card isn’t saving any text in the loop. I have a test write in the setup and it works fine, but nothing after writes to the card.
#include <SdFat.h>
#include <adafruit-ina219.h>
#include <Adafruit_mfGFX.h>
#include <Adafruit_ILI9341.h>
double blip=0;
Adafruit_INA219 ina219;
const int LED = D7;
double seconds;
double secondsi=Time.second();
String current;
bool shocked;
File myFilex;
float current_mA = 0;
#define TFT_DC D5
#define TFT_CS D4
#define STMPE_CS D3
#define SD_CS D2
const int SD_CS_PIN = SS;
SdFat SD;
File myFile;
Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC);
int initial=0;
void setup(void)
{ SPI.begin(SD_CS_PIN);
digitalWrite(SD_CS_PIN,HIGH);
tft.begin();
delay(1000);
tft.fillScreen(ILI9341_BLACK);
if (!SD.begin(SD_CS_PIN,SD_SCK_MHZ(50))) {
tft.println("initialization failed!");
return;}
uint32_t currentFrequency;
pinMode(LED,OUTPUT);
Serial.begin(115200);
Serial.println("Hello!");
//Mesh.connect();
// Initialize the INA219.
// By default the initialization will use the largest range (32V, 2A). However
// you can call a setCalibration function to change this range (see comments).
digitalWrite(LED,HIGH);
Wire.begin();
ina219.begin();
digitalWrite(LED,LOW);
// To use a slightly lower 32V, 1A range (higher precision on amps):
//ina219.setCalibration_32V_1A();
// Or to use a lower 16V, 400mA range (higher precision on volts and amps):
ina219.setCalibration_16V_400mA();
Serial.println("Measuring voltage and current with INA219 ...");
shocked=false;
myFile = SD.open("Test1.txt", FILE_WRITE);
if (myFile) {
Serial.print("Writing to test.txt...");
myFile.println("testing 1, 2, 3.");
// close the file:
myFile.close();
tft.fillScreen(ILI9341_GREEN);
tft.println("done.");
} else {
// if the file didn't open, print an error:
Serial.println("error opening test.txt");
tft.fillScreen(ILI9341_RED);
return;
void loop(void)
{myFilex=SD.open("Test2.txt", FILE_WRITE);
if (initial<10){blip+=ina219.getCurrent_mA(); initial+=1;}
else{
if (initial==10){blip=blip/10; initial+=1;}
else{
bool zero=false;
current_mA = ina219.getCurrent_mA()-blip;
//Serial.println(current_mA);
//delay(1000);}
current=String(current_mA)+" mA";
// Mesh.publish("Current",current);
if (current_mA>.3&¤t_mA<1){
seconds =Time.second();
myFilex.println("String(seconds-secondsi)");
if (current_mA>1){
myFilex.println(seconds-secondsi);}
tft.setCursor(0, 0);
tft.setTextColor( ILI9341_RED, ILI9341_YELLOW);
tft.setTextSize(8);
tft.println(current_mA);
myFilex.close();
else if (zero==false&¤t_mA<0.3){
zero=true;
tft.setTextSize(8);
tft.println(0.0);
shocked=false;}
