Cant install CLI on windows 10 PC
I can’t seem to install the CLI on a windows 10 PC
I downloaded and ran the Windows installer. and followed the directions here
https://docs.particle.io/tutorials/developer-tools/cli/
Here is the error I get in powershell when running “particle setup”
PS C:\Users\jham\AppData\Local\particle> particle setup
Program ‘particle.exe’ failed to run: The operation was canceled by the userAt line:1 char:1
  • particle setup
At line:1 char:1
  • particle setup
  •   + CategoryInfo          : ResourceUnavailable: (:) [], ApplicationFailedException
      + FullyQualifiedErrorId : NativeCommandFailed
Here is my directory
PS C:\Users\jham\AppData\Local\particle\bin> dir
Directory: C:\Users\jham\AppData\Local\particle\bin
Mode LastWriteTime Length Name
-a---- 4/16/2019 12:48 PM 48991 dfu-prefix.exe
-a---- 4/16/2019 12:48 PM 48406 dfu-suffix.exe
-a---- 4/16/2019 12:48 PM 280795 dfu-util-static.exe
-a---- 4/16/2019 12:48 PM 124040 dfu-util.exe
-a---- 4/16/2019 12:48 PM 199705 libusb-1.0.dll
-a---- 5/30/2019 11:54 AM 7349248 particle.exe
You shouldn’t need to cd into the directory where CLI got installed to (try doing it from your %HOMEPATH%)
Also try running particle setup via cmd instead of powershell
Thanks, running from cmd worked !
