Hi guys, I’m trying out the github example to control the relays with my Electron but it doesn’t work.
The firmware build with no errors but when it runs on the Electron the serial monitor shows
First this include statement looks like you are targeting a system 0.5.2 or before and next has this board got address jumpers and if are they set right?
Did you import the NCD4Relay library into your project? Also, you might want to try the shorter include like they use in the examples for that library (I don’t know if this makes a difference or not),
