Ifttt + 4 relay shield
hello
im looking for a library to use IFTTT with the 4 relay shield
is this library the one?
internet_Relays.cpp
thanks
Have you tried it? No reason it shouldn’t work.
No Sir
I needed previous confirmation before buying the boards.
You don’t really need any library to have IFTTT talk to the Particle devices - it’s all in the stock APIs
Sorry, I meant if its the correct library to control relays over internet
The library for the relay shield is here
https://build.particle.io/libs/RelayShield/0.0.6/tab/RelayShield.cpp
But for that too: No library actually needed.
The relays are connected to the following pins
#define relay1 D3
#define relay2 D4
#define relay3 D5
#define relay4 D6
And with that you just use pinMode() and digitalWrite() as you’d do with any other GPIO manipulation.
is any complete library ready to use ? im not (yet) a programming code guy !
Hmm, even using a library does also require some basic programming - or are you asking for a ready-to-use solution for your particular problem?
I normally use NCD boards with their standard library.
I just wanted to try particle shield board and be sure I can use internet relays for a standard online+ifttt use.
The Particle Relay Shield is a lot easier to control than the NCD’s.
  pinMode(D3, OUTPUT);
  digitalWrite(D3, !digitalRead(D3));
  delay(1000);
This is all you need to have Realay 1 toggle on/off every second.
