Hey everyone,
A friend and I are making a rain gauge for our graduation project, and we are using a hall sensor with a magnet, that measures every time the magnet comes by. And out of this measurements we calculate the rainfall. Only, the problem is, we’re not really stars when it comes to programming, and we have two errors in our code, so maybe someone can help us, btw, my apologies for some mistakes in English, it’s not our native language, thanks in advance
This is our code:
script do to time measurements (number of pulses within an interval.
- every second, a measurement (as integer) is written over the Serial line
- every 5 seconds, a measurement (as integer) is published to the Cloud
- the function "readPulses" is call-able from the Cloud. A measurement (as integer!)
is returned.
//the interval used to measure, in milliseconds
int measureTime = 1000;
int measureTimeOnline = 60000;
//the name of the event.
String eventName = "measurement/Regenmeter";
//the pin to use for measuring.
int inPin = D1;
//some constants and constructs
int measuredPulsesSerial = 0;
int measuredPulsesOnline = 0;
int measuredPulsesSerialPrevious = 0;
int status = 0;
Timer measureTimer(measureTime, readAndSerial);
Timer measureTimerOnline(measureTimeOnline, readAndPublish);
void setup(){
//start Serial communication
//set analogPin to INPUT
pinMode(inPin, INPUT);
//attach an interupt for handling counting the pulses
//start timer that calls measurement en sends results over Serial
measureTimer.start();
measureTimerOnline.start();
//make measuredPulsesSerialPrevious available online
Particle.variable("measurement",measuredPulsesSerialPrevious);
//make readAnalogValue available online, returns measurement as integer
Particle.function("readPulsesPerSecond",readPulses);
void loop(){
if ((digitalRead(inPin)==HIGH) & (status == 0)){
Serial.println("pulse");
measuredPulsesSerial++;
measuredPulsesOnline++;
status = 1;
delay(50);
} else if ((digitalRead(inPin)==LOW) & (status == 1)){
status = 0;
void readAndSerial(){
Serial.println(measuredPulsesSerial);
measuredPulsesSerialPrevious=measuredPulsesSerial;
measuredPulsesSerial=0;
void readAndPublish(){
Serial.println("publish!");
float x = (float) measuredPulsesOnline;
float MM = ((0.0201*x*x)+(0.9038*x))/39.8;
Particle.publish(eventName, (String) MM);
measuredPulsesOnline=0;
//readPulses only returns the nr of pulses from the previous second.
int readPulses(String Command){
return measuredPulsesSerialPrevious;
And the errors:
regenmeter.cpp:2:1: error: 'script' does not name a type
regenmeter.cpp:26:20: error: 'measureTime' was not declared in this scope
int inPin = D1;
In file included from ../wiring/inc/spark_wiring.h:48:0,
from ./inc/application.h:36,
from regenmeter.cpp:3:
../wiring/inc/spark_wiring_cloud.h: In instantiation of 'static bool CloudClass::function(const T&, Types ...) [with T = char [20]; Types = {int (*)(String)}]':
regenmeter.cpp:47:53: required from here
../wiring/inc/spark_wiring_cloud.h:188:9: error: static assertion failed:
In Particle.function, name must be less than 12 characters
static_assert(!IsStringLiteral(name) || sizeof(name) <= USER_FUNC_KEY_LENGTH + 1,
make[1]: *** [../build/target/user/platform-6regenmeter.o] Error 1
make: *** [user] Error 2
Error: Could not compile. Please review your code.
