Hi everyone, I’m making a hydrometer and I’m able to publish the relative humidity, but I also want to publish the dew point and I’ve tried a lot, but I failed everytime I tried. Is there maybe anyone who could help me out? Underneath is my code, and in this code I want to add the formula:
DWP=(237,7FD)/(17,27-FD)
with
FD=(17,27analogMeas0)/(237,7 + analogMeas0) + ln(RH/100)
My code:
#include "math.h"
script do to analog measurements.
- every second, a measurement (as floating point) is written over the Serial line
- every 5 seconds, a measurement (as floating point) is published to the Cloud
- the function "readAnalog" is call-able from the Cloud. A measurement (as integer!)
is returned.
//the interval used to measure, in milliseconds
int measureTime = 1000;
int measureTimeOnline = 30000;
//the name of the event.
String eventName0 = "Temperatuur, normaal";
String eventName1 = "Temperatuur, natte bol";
String eventName2 = "Relatieve Vochtigheid";
//the pin to use for measuring.
int analogPin0 = A0;
int analogPin1 = A1;
//some constants and constructs
int measuredBitValue = 0;
float measuredValue0 = 0.0;
float measuredValue1 = 0.0;
Timer measureTimer(measureTime, readAndSerial);
Timer measureTimerOnline(measureTimeOnline, readAndPublish);
void setup(){
//start Serial communication
//set analogPin to INPUT
pinMode(analogPin0, INPUT);
pinMode(analogPin1, INPUT);
//start timer that calls measurement en sends results over Serial
measureTimer.start();
measureTimerOnline.start();
void loop(){}
void readAndSerial(){
int analogMeas0 = analogRead(analogPin0);
int analogMeas1 = analogRead(analogPin1);
Serial.print("0: ");
Serial.print(analogMeas0);
Serial.print(" 1: ");
Serial.println(analogMeas1);
void readAndPublish(){
float analogMeas0 = round((((analogRead(analogPin0)*0.8056640625)- 500)/10)*10)/10;
float analogMeas1 = round((((analogRead(analogPin1)*0.8056640625)- 500)/10)*10)/10;
float RH = round((RelVocht(analogMeas1,analogMeas0))*10)/10;
Particle.publish(eventName0, (String) analogMeas0);
Particle.publish(eventName1, (String) analogMeas1);
Particle.publish(eventName2, String(RH,1) + " % en " + String(analogMeas0,1));
float RelVocht(float T1, float T0){
float Yb = 0.61*pow(2.71828184, 17.3*T1/(237+T1));
float Pdmax = 0.61*pow(2.71828184, 17.3*T0/(237+T0));
float Pd = -0.066*(T0-T1)+Yb;
float RelH = 100*Pd/Pdmax;
return RelH;
