My electron has already connect to cloud and I using the code 1_GPS-FEATURES.INO, the GPS fix is breathing red but there is nothing happend on my channel. Can you please tell me what I should do?
Your red GPS LED should actually be off when you've got a fix. If is still blinks, the position is not found.
So, should I bring it outside the building fot it can find it’s position?
That would be a starting point and should work.
But depending on the free view of the sky in your area that might still not be enough.
If that’s not good enough you might need to try with an active antenna too.
@ScruffR Thank you so much
Thanks @ScruffR!
Did you ever figure this out. I am not able to get the location to update.
