Using digitalWrite(led1, LOW);, can I use a variable in place of the β1β to turn LEDs on/off?
No, you canβt use a variable in place of the β1β, but you can put the pin numbers into an array, and use them in a loop.
int leds[] = {D0,D1,D2,D3,D4,D5,D6,D7};
for (int i=0; i<8; i++) {
digitalWrite(leds[i], HIGH);
delay(200);
digitalWrite(leds[i], LOW);
delay(200);
Technically, you donβt really need the array since D0=0, D1=1 etc. (so digitalWrite(i, HIGH) would work), but I think the code is safer and more clear if you do it the way I showed with the array.
Ah, thanks.
