Blink an LED within a loop
I am currently playing with my photon and I have the idea that I want to blink an LED, easy enough :wink:
but how do I do this within an existing loop?:
int setStatus(String status) {
  if(status == "DoNotDisturb"){
    RGB.color(0, 0, 255);
    digitalWrite(ledR, HIGH);
    // Well the LED should be blinking
    digitalWrite(ledG, LOW);
    digitalWrite(ledY, LOW);
  else if(....
any Ideas (I assume I am blocked somewhere, the question looks so stupid) or is this just not possible, I cannot put in another loop (as it will of course be a loop of death :slight_smile: )
Regards,
Jan
@sixpack
you could try something like this, allowing you to set which led you want to blink in your RGB led:
      blinkRGB(true, false, false, 250);
  blinkRGB(bool red, bool green, bool blue, int rate)
    static unsigned long lastBlinkTime = 0;
    if(millis() - lastBlinkTime > rate)
      if(red)
        digitalWrite(redPin, !digitalRead(redPin);
      else
        digitalWrite(redPin, LOW);
      if(green)
        digitalWrite(greenPin, !digitalRead(greenPin);
      else
        digitalWrite(greenPin, LOW);
      if(blue)
        digitalWrite(bluePin, !digitalRead(bluePin);
      else
        digitalWrite(bluePin, LOW);
      lastBlinkTime = millis();
a down and dirty way…
