I am using my particle to read an XML file (using myHandler()), parse it (using splitNumbersOut() and tryExtractString()), and then use those values to move servos (using runThemAll()). If I call runThemAll() from my iphone particle app using runthemaller(), it works great. However, if I call runThemAll() from the Loop() or though IFTTT, I get the red light, the particle goes offline, and then restarts. Thanks in advance for any help!!!
Full Code:
int Servo_Location[] = {5,5,5,5,5};
Servo servo1;
Servo servo2;
Servo servo3;
Servo servo4;
Servo servo5;
Servo Scycler[5]= {servo1, servo2, servo3, servo4, servo5};
String weight_string, weather_string, lion_string, choice_string, dow_string, weatherTom_string;
int servoPos = 120;
String xml_result;
String lastrun = "not yet";
boolean restarted = true;
//THE SET UP
// Set time zone to Eastern USA daylight saving time
Time.zone(-4);
//ATTACH THE SERVOS TO THE DIFFERENT PINS OF THE PHOTON
//Attach Servoβs
servo1.attach(D0);
servo2.attach(D1);
servo3.attach(D2);
servo4.attach(D3);
servo5.attach(WKP);
//Particle Functions
Particle.subscribe("hook-response/Bar_Info", myHandler, MY_DEVICES);
Particle.function("servo", servoControl);
Particle.function("setter", setterControl);
Particle.function("runthemaller", runthemaller);
Particle.function("Timedrun", Timedrun);
//Particle Variables
Particle.variable("SERVO1", Servo_Location[0]);
Particle.variable("SERVO2", Servo_Location[1]);
Particle.variable("SERVO3", Servo_Location[2]);
Particle.variable("SERVO4", Servo_Location[3]);
Particle.variable("SERVO5", Servo_Location[4]);
Particle.variable("timer", lastrun);
//WEB FUNCTIONS
void myHandler(const char *event, const char *data)
// Handle the integration response
xml_result = String(data);
Particle.publish("XML Result", xml_result, PUBLIC);
StringReset();
splitNumbersOut(0,weather_string, ",");
int setterControl(String command)
Particle.publish("Setter_String", command, PUBLIC);
int i = command.toInt();
int z = constrain(i, 0, 100);
servoRunner(z,z,z,z,z);
return 1;
int servoControl(String command)
int newPos = command.toInt();
servoPos = constrain( newPos, 0 , 180);
servo1.write(servoPos);
//βββββββββββ
//Test that the string is split correctly
//βββββββββββ
Particle.publish("position", command, PUBLIC);
delay(2000);
showWeight();
delay(2000);
return 1;
int runthemaller(String command)
runThemAll();
Particle.publish("runthemaller", "rta_over", PUBLIC);
return 1;
int Timedrun(String command)
Particle.publish("runthemaller", command, PUBLIC);
int ttime = Time.hour();
if ((ttime > 8) && (ttime < 20))
Particle.publish("in_Loop", "runningthemall", PUBLIC);
runThemAll();
else
Particle.publish("in_Loop", "wrong time", PUBLIC);
Particle.publish("in_Loop", "Timed_over", PUBLIC);
return 1;
//DATA PARSING FUNCTIONS
void StringReset()
weight_string = tryExtractString(0, xml_result, "weight=\"", "\"");
weather_string = tryExtractString(0, xml_result, "weather=\"", "\"");
weatherTom_string = tryExtractString(0, xml_result, "weather_tom=\"", "\"");
lion_string = tryExtractString(0, xml_result, "lion=\"", "\"");
choice_string = tryExtractString(0, xml_result, "choice=\"", "\"");
dow_string = tryExtractString(0, xml_result, "choice=\"", "\"");
//βββββββββββ
//Test that the weather and weight are set
//βββββββββββ
// Particle.publish("temp_in_reset", weather_string, PUBLIC);
// Particle.publish("weight_in_reset", weight_string, PUBLIC);
String splitNumbersOut (int matchNum, String str, const char* end) {
if (str == NULL) {
return NULL;
int count =0;
while (count<5)
int lastIdx =0;
int idx = str.indexOf(end);
Servo_Location[count] = str.substring(lastIdx, idx).toInt();
str=str.substring(idx+1);
count++;
StringReset();
String tryExtractString(int matchNum, String str, const char* start, const char* end) {
if (str == NULL) {
return NULL;
int count = 0;
int lastIdx = 0;
while (count <= matchNum) {
int idx = str.indexOf(start, lastIdx);
int endIdx = str.indexOf(end, lastIdx + idx + strlen(start));
lastIdx = endIdx;
if (count == matchNum) {
return str.substring(idx + strlen(start), endIdx);
count++;
//SERVO CONTROLS
void servoRunner(int a, int b, int c, int d, int e)
//m is the integer to mutliply the input.
int m = 1.7;
//f is the amount that needs to be adjusted to keep it in the servo range
int f = 10;
servo1.write(a*m + f);
delay(500);
servo2.write(180 - b*m - f);
delay(500);
servo3.write(c*m + f);
delay(500);
servo4.write(180 - d*m - f);
delay(500);
servo5.write(e*m + f);
delay(500);
//LETS PUT ALL THE DATA RUNNERS HERE
void runThemAll()
theDance();
Particle.publish("this", weather_string, PUBLIC);
showWeight();
delay(3000);
servoRunner(50,50,50,50,50);
delay(500);
showLions();
delay(3000);
delay(500);
int slimer = Time.hour();
lastrun = String(slimer);
Particle.publish("time", lastrun, PUBLIC);
if (slimer < 18)
showWeather();
else
showWeatherTom();
Particle.publish("this", "Run_Over", PUBLIC);
void theDance()
servoRunner(100,75,50,25,0);
delay(1500);
servoRunner(0,25,50,75,100);
delay(1500);
void showWeather()
Particle.publish("_in_showWeather", weather_string, PUBLIC);
servoRunner(Servo_Location[0], Servo_Location[1],Servo_Location[2], Servo_Location[3],Servo_Location[4]);
void showWeight()
splitNumbersOut(0,weight_string, ",");
//βββββββββββ
//βββββββββββ
Particle.publish("_in_showWeight", weight_string, PUBLIC);
void showWeatherTom()
splitNumbersOut(0, weatherTom_string, ",");
Particle.publish("_in_showWeatherTom", weatherTom_string, PUBLIC);
void showChoice()
splitNumbersOut(0,choice_string, ",");
Particle.publish("_in_showChoice", choice_string, PUBLIC);
void showLions()
splitNumbersOut(0,lion_string, ",");
Particle.publish("_in_showLions", lion_string, PUBLIC);
//THE LOOP
// Get some data
String data = String(10);
// Trigger the integration
Particle.publish("Bar_Info", data, PRIVATE);
// Wait 60 seconds
delay(60000);
if (restarted)
runThemAll();
delay (50000);
restarted = false;
delay(120000);
int mtime =Time.minute();
if ((ttime > 7) && (ttime < 20) && (mtime==0))
runThemAll();
