Bug Report: SPI Slave Mode: MSBFIRST non-functional
Hello,
Not sure where to post bugs - but it would appear that SPI.setBitOrder(MSBFIRST);
does not work.
Has Particle thoroughly tested this?
If so; please post a COMPLETE SPI SLAVE configuration that has passed all combinations of MODES and bit orders - so we can compare apples to apples.
I have pretty much verified with an analyzer that MSBFIRST doesn’t work from the Photon. There is still a small chance this could be due to a set-up variable on my end due to rather incomplete examples for SPI provided by Photon.
So, if you guys have a QA dept. that has thoroughly tested this - please attach the code to a reply and I will test.
I will post my code here so everyone can see it.
Thanks In Advance,
John W.
// #include "lib3.h"
// #include "lib2.h"
// #include "lib1.h"
#include "application.h"
#define SLAVE    //  (1)  // defines Photon to be in slave mode
SYSTEM_MODE(SEMI_AUTOMATIC);
SYSTEM_THREAD(ENABLED);
// #define WIFI_SSID (123456)
// #define WIFI_PWD    (XXXXYYYYZZZ)
/* Define either MASTER or SLAVE operating mode */
//#define MASTER
// #define SLAVE
// static uint8_t rx_buffer[64];
// static uint8_t tx_buffer[64];
static uint8_t rx_buffer[10];
static uint8_t tx_buffer[10];
static volatile uint32_t select_state = 0x00;
static volatile uint32_t transfer_state = 0x00;
int rx_val;
void onTransferFinished() {
//    digitalWriteFast(A0, HIGH);   // we are in slave mode
    transfer_state = 1;
#ifdef SLAVE
void onSelect(uint8_t state) {
    if (state)
        select_state = state;
/* executes once at startup */
    SPI.onSelect(onSelect);
    SPI.begin(SPI_MODE_SLAVE, A2);
    SPI.setBitOrder(LSBFIRST);
    SPI.setDataMode(SPI_MODE3);
    memset(rx_buffer, 0, sizeof(rx_buffer));
    for (int i = 0; i < sizeof(tx_buffer); i++)
        tx_buffer[i] = (uint8_t)i;
/* executes continuously after setup() runs */
       WiFi.on();
       delay(1000);
    while(!(WiFi.hasCredentials()))
        Serial1.println("setting WiFi credentials");
        WiFi.setCredentials("123456", "XXXXYYYYZZZZ");
         WiFi.connect();
        Particle.connect();
//         Spark.process();
    while (1) {
        while(select_state == 0);
        select_state = 0;
        transfer_state = 0;
        SPI.transfer(tx_buffer, rx_buffer, sizeof(rx_buffer), onTransferFinished);
        while(transfer_state == 0);
        if (SPI.available() > 0) {
            Serial.printf("Received %d (0x%02x) bytes", SPI.available(), SPI.available());
            Serial.println();
            for (int i = 0; i < SPI.available(); i++) {
                Serial.printf("%02x ", rx_buffer[i]);
                rx_val = rx_buffer[5];
            Serial.println();
            // if (rx_buffer[transferLength - 1] != 0x00) {
            //     Serial.println("Error");
            //     while(true);
            Particle.variable("SPI RX", &rx_val, INT);
            Particle.publish("SPI RX", (const char *)rx_val, 200, PUBLIC);
            Particle.process();
            tx_buffer[i] = rx_buffer[i];
            rx_val = 0;
            delay(750);
#else
static int random_range(int minVal, int maxVal)
    return rand() % (maxVal-minVal+1) + minVal;
    SPI.begin(SPI_MODE_MASTER, A2);
    memset(tx_buffer, 0, sizeof(tx_buffer));
    uint32_t seed = millis();
    srand(seed);
    while (1) {
        int transferLength = random_range(1, sizeof(tx_buffer));
        for (int i = 0; i < transferLength; i++)
            tx_buffer[i] = (uint8_t)(transferLength - i - 1);
        digitalWrite(A2, LOW);
        delay(1);
        transfer_state = 0;
        SPI.transfer(tx_buffer, rx_buffer, transferLength, onTransferFinished);
        digitalWrite(A2, HIGH);
        Serial.printf("Sent %d (0x%02x) bytes, got back:", transferLength, transferLength);
        Serial.println();
        for (int i = 0; i < transferLength; i++) {
        Serial.println();
        if (rx_buffer[transferLength - 1] != (uint8_t)(transferLength - 1)) {
            delay(1000);
        delay(100);
#endif
The best place to file a bug report would be here by opening a new issue (or check if there is one already)
Could you try setting the configuration before SPI.begin()
Also, the SPI Master code does not explicitly set:
:smiley:
Appears to be something similar here:
Thanks guys - I will see what I can do based on your replies and this bug report and report back here.
I suppose the SPI operation does have a default mode; correct?
Nope, this was a different issue and the root cause for this might have had to do with the boot-up behaviour of some D-pins with default pull-resistors.
Please report back, once you have tried the tips from above.
