I've tried to restore the firmware of my boron based on this link:
However the board doesn't seem to work still. So I'm wondering how to do a full firmware reset for the boron.
Hey @enoryt56
You can check out my suggestions here. You can use an NRF52DK to unbork your Boron.
Good luck! ![]()
You can also use the Particle Debugger to restore if you have one
https://docs.particle.io/support/particle-tools-faq/jtag/#openocd-commands-3rd-generation-
Thank you very much
I actually found another one of your other links being very useful as I manually used the commander method:
https://www.jaredwolff.com/how-to-unbrick-particle-mesh-using-jlink/#!
Awesome. Glad you found it useful.
