I have a program that worked fine a couple weeks ago on my Photon, but now every time I try to compile and flash it, the Photon simply appears to go into Safe mode (breathing magenta). Am I making a mistake using Particle Dev? Do I need to move (back) to the online IDE?
I am able to flash Tinker and have it work fine.
I’ve wasted tons of time on this, refreshed 4.6 via DFU in case I compromised an update when getting a bit impatient and power cycling a magenta breathing Photon.
Is it possible my program requires something that needs an update and that’s why it breathes magenta?
There’s a ton of helpful information on this forum, but there is a TON of information that’s a bit hard to get through.
I had this same thing happen on another Photon, but somehow managed to get through it via “particle update”.
