Im brazilian and really would like to buy an Electron 3G Kit, when looking at the compatible countries for electron I found Brazil in Eur/Asia/Afr option (Brazil is located in South America). Should I buy the Americas Kit or the Eur/Asia/Afr one?
You can look at this map to see why Brazil is listed for the U270 Electron.
http://www.worldtimezone.com/gsm.html
The U260 (US version) does not support the 2100MHz band which is used by the 3G providers in Brazil and the 2G fallback is also 900/1800 which is again supported on the U270 but not on U260.
thanks!
