Boron's flashing green
I have 2 Borons that are stuck flashing green, trace below. They are both looping through the same trace statements. I have tried moving the device to another location in the house, same problem. This device was working fine a couple days ago then suddenly this. Same with the other device I'm using. I did notice the carrier linked to the last communication was ATT vs. T-Mobile, which has generally been the provider the devices choose at my test location, did anything change in carrier preferences?
Serial connection closed. Attempting to reconnect...
Serial monitor opened successfully:
0000003775 [ncp.client] INFO: Using internal SIM card
0000006338 [mux] INFO: Starting GSM07.10 muxer
0000006338 [mux] INFO: Opening mux channel 0
0000006339 [mux] INFO: GSM07.10 muxer thread started
0000006342 [mux] INFO: Opening mux channel 1
0000611725 [ncp.client] WARN: Resetting the modem due to the network registration timeout
0000611726 [mux] INFO: Stopping GSM07.10 muxer
0000611727 [mux] INFO: Gracefully stopping GSM07.10 muxer
0000611727 [mux] INFO: Closing all muxed channels
0000611728 [mux] INFO: Closing mux channel 1
0000611728 [mux] INFO: Muxed channel 2 already closed
0000611728 [mux] INFO: Muxed channel 3 already closed
0000611729 [mux] INFO: Muxed channel 4 already closed
0000612996 [mux] INFO: Sending CLD (multiplexer close down)
0000612998 [mux] INFO: Received response to CLD or timed out, exiting multiplexed mode
0000612999 [mux] INFO: GSM07.10 muxer thread exiting
0000612999 [mux] INFO: GSM07.10 muxer stopped
0000620975 [ncp.client] INFO: Using internal SIM card
0000623549 [mux] INFO: Starting GSM07.10 muxer
0000623549 [mux] INFO: Opening mux channel 0
0000623550 [mux] INFO: GSM07.10 muxer thread started
0000623553 [mux] INFO: Opening mux channel 1
0001227964 [ncp.client] WARN: Resetting the modem due to the network registration timeout
0001227965 [mux] INFO: Stopping GSM07.10 muxer
0001227966 [mux] INFO: Gracefully stopping GSM07.10 muxer
0001227966 [mux] INFO: Closing all muxed channels
0001227966 [mux] INFO: Closing mux channel 1
0001227967 [mux] INFO: Muxed channel 2 already closed
0001227967 [mux] INFO: Muxed channel 3 already closed
0001227968 [mux] INFO: Muxed channel 4 already closed
0001229235 [mux] INFO: Sending CLD (multiplexer close down)
0001229238 [mux] INFO: Received response to CLD or timed out, exiting multiplexed mode
0001229239 [mux] INFO: GSM07.10 muxer thread exiting
0001229239 [mux] INFO: GSM07.10 muxer stopped
0001237116 [ncp.client] INFO: Using internal SIM card
0001239688 [mux] INFO: Starting GSM07.10 muxer
0001239689 [mux] INFO: Opening mux channel 0
0001239689 [mux] INFO: GSM07.10 muxer thread started
0001239693 [mux] INFO: Opening mux channel 1
0001843130 [ncp.client] WARN: Resetting the modem due to the network registration timeout
0001843131 [mux] INFO: Stopping GSM07.10 muxer
0001843132 [mux] INFO: Gracefully stopping GSM07.10 muxer
0001843132 [mux] INFO: Closing all muxed channels
0001843132 [mux] INFO: Closing mux channel 1
0001843133 [mux] INFO: Muxed channel 2 already closed
0001843133 [mux] INFO: Muxed channel 3 already closed
0001843134 [mux] INFO: Muxed channel 4 already closed
0001844401 [mux] INFO: Sending CLD (multiplexer close down)
0001844404 [mux] INFO: Received response to CLD or timed out, exiting multiplexed mode
0001844405 [mux] INFO: GSM07.10 muxer thread exiting
0001844405 [mux] INFO: GSM07.10 muxer stopped
0001852377 [ncp.client] INFO: Using internal SIM card
0001854947 [mux] INFO: Starting GSM07.10 muxer
0001854948 [mux] INFO: Opening mux channel 0
0001854948 [mux] INFO: GSM07.10 muxer thread started
0001854951 [mux] INFO: Opening mux channel 1
0002463887 [ncp.client] WARN: Resetting the modem due to the network registration timeout
0002463888 [mux] INFO: Stopping GSM07.10 muxer
0002463888 [mux] INFO: Gracefully stopping GSM07.10 muxer
0002463889 [mux] INFO: Closing all muxed channels
0002463889 [mux] INFO: Closing mux channel 1
0002463890 [mux] INFO: Muxed channel 2 already closed
0002463890 [mux] INFO: Muxed channel 3 already closed
0002463891 [mux] INFO: Muxed channel 4 already closed
0002465158 [mux] INFO: Sending CLD (multiplexer close down)
0002465161 [mux] INFO: Received response to CLD or timed out, exiting multiplexed mode
0002465161 [mux] INFO: GSM07.10 muxer thread exiting
0002465162 [mux] INFO: GSM07.10 muxer stopped
0002472945 [ncp.client] INFO: Using internal SIM card
0002475518 [mux] INFO: Starting GSM07.10 muxer
0002475518 [mux] INFO: Opening mux channel 0
0002475519 [mux] INFO: GSM07.10 muxer thread started
0002475521 [mux] INFO: Opening mux channel 1
0003711459 [ncp.client] WARN: Resetting the modem due to the network registration timeout
0003711460 [mux] INFO: Stopping GSM07.10 muxer
0003711460 [mux] INFO: Gracefully stopping GSM07.10 muxer
0003711461 [mux] INFO: Closing all muxed channels
0003711461 [mux] INFO: Closing mux channel 1
0003711462 [mux] INFO: Muxed channel 2 already closed
0003711462 [mux] INFO: Muxed channel 3 already closed
0003711463 [mux] INFO: Muxed channel 4 already closed
0003712730 [mux] INFO: Sending CLD (multiplexer close down)
0003712732 [mux] INFO: Received response to CLD or timed out, exiting multiplexed mode
0003712733 [mux] INFO: GSM07.10 muxer thread exiting
0003712733 [mux] INFO: GSM07.10 muxer stopped
0003721742 [ncp.client] INFO: Using internal SIM card
0003724322 [mux] INFO: Starting GSM07.10 muxer
0003724322 [mux] INFO: Opening mux channel 0
0003724323 [mux] INFO: GSM07.10 muxer thread started
0003724325 [mux] INFO: Opening mux channel 1
0006823267 [ncp.client] WARN: Resetting the modem due to the network registration timeout
0006823267 [mux] INFO: Stopping GSM07.10 muxer
0006823268 [mux] INFO: Gracefully stopping GSM07.10 muxer
0006823268 [mux] INFO: Closing all muxed channels
0006823269 [mux] INFO: Closing mux channel 1
0006823269 [mux] INFO: Muxed channel 2 already closed
0006823270 [mux] INFO: Muxed channel 3 already closed
0006823270 [mux] INFO: Muxed channel 4 already closed
0006824537 [mux] INFO: Sending CLD (multiplexer close down)
0006824539 [mux] INFO: Received response to CLD or timed out, exiting multiplexed mode
0006824540 [mux] INFO: GSM07.10 muxer thread exiting
0006824540 [mux] INFO: GSM07.10 muxer stopped
0006834041 [ncp.client] INFO: Using internal SIM card
0006836616 [mux] INFO: Starting GSM07.10 muxer
0006836617 [mux] INFO: Opening mux channel 0
0006836617 [mux] INFO: GSM07.10 muxer thread started
0006836620 [mux] INFO: Opening mux channel 1
0007442991 [ncp.client] WARN: Resetting the modem due to the network registration timeout
0007442992 [mux] INFO: Stopping GSM07.10 muxer
0007442992 [mux] INFO: Gracefully stopping GSM07.10 muxer
0007442993 [mux] INFO: Closing all muxed channels
0007442993 [mux] INFO: Closing mux channel 1
0007442993 [mux] INFO: Muxed channel 2 already closed
0007442994 [mux] INFO: Muxed channel 3 already closed
0007442995 [mux] INFO: Muxed channel 4 already closed
0007444262 [mux] INFO: Sending CLD (multiplexer close down)
0007444265 [mux] INFO: Received response to CLD or timed out, exiting multiplexed mode
0007444265 [mux] INFO: GSM07.10 muxer thread exiting
0007444266 [mux] INFO: GSM07.10 muxer stopped
0007452240 [ncp.client] INFO: Using internal SIM card
0007457126 [mux] INFO: Starting GSM07.10 muxer
0007457127 [mux] INFO: Opening mux channel 0
0007457127 [mux] INFO: GSM07.10 muxer thread started
0007457129 [mux] INFO: Opening mux channel 1
0008059310 [ncp.client] WARN: Resetting the modem due to the network registration timeout
0008059311 [mux] INFO: Stopping GSM07.10 muxer
0008059311 [mux] INFO: Gracefully stopping GSM07.10 muxer
0008059312 [mux] INFO: Closing all muxed channels
0008059313 [mux] INFO: Closing mux channel 1
0008059313 [mux] INFO: Muxed channel 2 already closed
0008059314 [mux] INFO: Muxed channel 3 already closed
0008059314 [mux] INFO: Muxed channel 4 already closed
0008060581 [mux] INFO: Sending CLD (multiplexer close down)
0008060584 [mux] INFO: Received response to CLD or timed out, exiting multiplexed mode
0008060584 [mux] INFO: GSM07.10 muxer thread exiting
0008060585 [mux] INFO: GSM07.10 muxer stopped
0008068892 [ncp.client] INFO: Using internal SIM card
0008071466 [mux] INFO: Starting GSM07.10 muxer
0008071467 [mux] INFO: Opening mux channel 0
0008071467 [mux] INFO: GSM07.10 muxer thread started
0008071471 [mux] INFO: Opening mux channel 1
0008711644 [ncp.client] WARN: Resetting the modem due to the network registration timeout
0008711645 [mux] INFO: Stopping GSM07.10 muxer
0008711646 [mux] INFO: Gracefully stopping GSM07.10 muxer
0008711646 [mux] INFO: Closing all muxed channels
0008711646 [mux] INFO: Closing mux channel 1
0008711647 [mux] INFO: Muxed channel 2 already closed
0008711647 [mux] INFO: Muxed channel 3 already closed
0008711648 [mux] INFO: Muxed channel 4 already closed
0008712915 [mux] INFO: Sending CLD (multiplexer close down)
0008712918 [mux] INFO: Received response to CLD or timed out, exiting multiplexed mode
0008712919 [mux] INFO: GSM07.10 muxer thread exiting
0008712919 [mux] INFO: GSM07.10 muxer stopped
0008722087 [ncp.client] INFO: Using internal SIM card
0008724664 [mux] INFO: Starting GSM07.10 muxer
0008724665 [mux] INFO: Opening mux channel 0
0008724665 [mux] INFO: GSM07.10 muxer thread started
0008724669 [mux] INFO: Opening mux channel 1
0009334037 [ncp.client] WARN: Resetting the modem due to the network registration timeout
0009334038 [mux] INFO: Stopping GSM07.10 muxer
0009334038 [mux] INFO: Gracefully stopping GSM07.10 muxer
0009334039 [mux] INFO: Closing all muxed channels
0009334039 [mux] INFO: Closing mux channel 1
0009334040 [mux] INFO: Muxed channel 2 already closed
0009334040 [mux] INFO: Muxed channel 3 already closed
0009334041 [mux] INFO: Muxed channel 4 already closed
0009335307 [mux] INFO: Sending CLD (multiplexer close down)
0009335310 [mux] INFO: Received response to CLD or timed out, exiting multiplexed mode
0009335310 [mux] INFO: GSM07.10 muxer thread exiting
0009335311 [mux] INFO: GSM07.10 muxer stopped
0009343481 [ncp.client] INFO: Using internal SIM card
0009346052 [mux] INFO: Starting GSM07.10 muxer
0009346053 [mux] INFO: Opening mux channel 0
0009346053 [mux] INFO: GSM07.10 muxer thread started
0009346057 [mux] INFO: Opening mux channel 1
0009955592 [ncp.client] WARN: Resetting the modem due to the network registration timeout
0009955593 [mux] INFO: Stopping GSM07.10 muxer
0009955593 [mux] INFO: Gracefully stopping GSM07.10 muxer
0009955594 [mux] INFO: Closing all muxed channels
0009955594 [mux] INFO: Closing mux channel 1
0009955595 [mux] INFO: Muxed channel 2 already closed
0009955595 [mux] INFO: Muxed channel 3 already closed
0009955596 [mux] INFO: Muxed channel 4 already closed
0009956863 [mux] INFO: Sending CLD (multiplexer close down)
0009956866 [mux] INFO: Received response to CLD or timed out, exiting multiplexed mode
0009956867 [mux] INFO: GSM07.10 muxer thread exiting
0009956867 [mux] INFO: GSM07.10 muxer stopped
0009964965 [ncp.client] INFO: Using internal SIM card
0009967541 [mux] INFO: Starting GSM07.10 muxer
0009967542 [mux] INFO: Opening mux channel 0
0009967542 [mux] INFO: GSM07.10 muxer thread started
0009967545 [mux] INFO: Opening mux channel 1
0011187512 [ncp.client] WARN: Resetting the modem due to the network registration timeout
0011187513 [mux] INFO: Stopping GSM07.10 muxer
0011187514 [mux] INFO: Gracefully stopping GSM07.10 muxer
0011187514 [mux] INFO: Closing all muxed channels
0011187514 [mux] INFO: Closing mux channel 1
0011187515 [mux] INFO: Muxed channel 2 already closed
0011187515 [mux] INFO: Muxed channel 3 already closed
0011187516 [mux] INFO: Muxed channel 4 already closed
0011188783 [mux] INFO: Sending CLD (multiplexer close down)
0011188786 [mux] INFO: Received response to CLD or timed out, exiting multiplexed mode
0011188787 [mux] INFO: GSM07.10 muxer thread exiting
0011188787 [mux] INFO: GSM07.10 muxer stopped
0011198388 [ncp.client] INFO: Using internal SIM card
0011200979 [mux] INFO: Starting GSM07.10 muxer
0011200979 [mux] INFO: Opening mux channel 0
0011200980 [mux] INFO: GSM07.10 muxer thread started
0011200983 [mux] INFO: Opening mux channel 1
0011813783 [ncp.client] WARN: Resetting the modem due to the network registration timeout
0011813784 [mux] INFO: Stopping GSM07.10 muxer
0011813784 [mux] INFO: Gracefully stopping GSM07.10 muxer
0011813784 [mux] INFO: Closing all muxed channels
0011813785 [mux] INFO: Closing mux channel 1
0011813785 [mux] INFO: Muxed channel 2 already closed
0011813786 [mux] INFO: Muxed channel 3 already closed
0011813786 [mux] INFO: Muxed channel 4 already closed
0011815053 [mux] INFO: Sending CLD (multiplexer close down)
0011815055 [mux] INFO: Received response to CLD or timed out, exiting multiplexed mode
0011815056 [mux] INFO: GSM07.10 muxer thread exiting
0011815056 [mux] INFO: GSM07.10 muxer stopped
0011823618 [ncp.client] INFO: Using internal SIM card
0011826193 [mux] INFO: Starting GSM07.10 muxer
0011826194 [mux] INFO: Opening mux channel 0
0011826194 [mux] INFO: GSM07.10 muxer thread started
0011827462 [mux] INFO: Opening mux channel 1
0012433186 [ncp.client] WARN: Resetting the modem due to the network registration timeout
0012433187 [mux] INFO: Stopping GSM07.10 muxer
0012433187 [mux] INFO: Gracefully stopping GSM07.10 muxer
0012433188 [mux] INFO: Closing all muxed channels
0012433188 [mux] INFO: Closing mux channel 1
0012433189 [mux] INFO: Muxed channel 2 already closed
0012433189 [mux] INFO: Muxed channel 3 already closed
0012433189 [mux] INFO: Muxed channel 4 already closed
0012434456 [mux] INFO: Sending CLD (multiplexer close down)
0012434459 [mux] INFO: Received response to CLD or timed out, exiting multiplexed mode
0012434459 [mux] INFO: GSM07.10 muxer thread exiting
0012434460 [mux] INFO: GSM07.10 muxer stopped
0012443557 [ncp.client] INFO: Using internal SIM card
0012448448 [mux] INFO: Starting GSM07.10 muxer
0012448449 [mux] INFO: Opening mux channel 0
0012448449 [mux] INFO: GSM07.10 muxer thread started
0012448451 [mux] INFO: Opening mux channel 1
0013060870 [ncp.client] WARN: Resetting the modem due to the network registration timeout
0013060871 [mux] INFO: Stopping GSM07.10 muxer
0013060872 [mux] INFO: Gracefully stopping GSM07.10 muxer
0013060872 [mux] INFO: Closing all muxed channels
0013060872 [mux] INFO: Closing mux channel 1
0013060873 [mux] INFO: Muxed channel 2 already closed
0013060873 [mux] INFO: Muxed channel 3 already closed
0013060874 [mux] INFO: Muxed channel 4 already closed
0013062141 [mux] INFO: Sending CLD (multiplexer close down)
0013062144 [mux] INFO: Received response to CLD or timed out, exiting multiplexed mode
0013062144 [mux] INFO: GSM07.10 muxer thread exiting
0013062145 [mux] INFO: GSM07.10 muxer stopped
0013071685 [ncp.client] INFO: Using internal SIM card
0013074260 [mux] INFO: Starting GSM07.10 muxer
0013074261 [mux] INFO: Opening mux channel 0
0013074261 [mux] INFO: GSM07.10 muxer thread started
0013074264 [mux] INFO: Opening mux channel 1
Double check that the SIM is activated in your account. You could get that behavior and log if the SIM is not activated.
You'd get a different error if the modem failed, or there were no compatible towers.
