Hi, Just wondering if it is possible to use the VUSB Pin as the primary supply rail for the boron and will using this pin still allow for lipo charging and fuel gage etc?
Yes, it should work without issue.
You might need to adjust the input current to what your source can supply:
https://docs.particle.io/reference/device-os/firmware/boron/#power-manager
