after normal boot LED flash sequence and particle console events, spark/device/diagnostics/update says the device is “unreachable” (the boron is breathing cyan at this time) when i try to flash firmware it fails when trying to flash firmware or DeviseOS over USB it is unable to enter DFU mode, is this fixable or do i need to get a new boron?
Hi, have you tried using the device restore tool?
thanks for the suggestion, reinstalling the every thing did the trick
