Hello! I was trying to dig up information and I believe I have an understanding, I would like to get confirmation if that’s the case. I was interested to know if I were to use the Boron, model BRN402, could it connect to the cellular towers in Jamaica? Thank you.
The BRN402, BRN404, and BRN404X cannot be used in Jamaica.
The reason is that these modules only support LTE Cat M1, and I believe there is no LTE Cat M1 in Jamaica, only regular LTE.
Can you recommend models that will work in Jamaica with the same spec for the BRN402?
There is currently no Boron model that will work in Jamaica. The B504e B-Series SoM module should work on 4G LTE, but is a different form-factor.
