I’m impressed with Blynk after using it. Today they announced a update to their app that allows you to share your projects and live data easily without the worry of the end user screwing the app up. See below.
Hey Blynkers,
This might be the most exciting update since our launch!
You’ve built so many cool projects with Blynk, we are amazed! But what’s the point of keeping them for yourself only? Wouldn’t it be great to share your fantastic creations with others?
From now on you are able to share the “Apps" you’ve made with Blynk with your family, friends or even customers.
As always, everything built @Blynk Garage Lab is super easy, fast and looks like magic.
You have the full control over the shared access:
people you’ve shared your project with can’t modify anything. They can only use it.
you can update your app, change the layout, add widgets and it’s immediately synced to everyone.
you can revoke access at any moment
How it works:
Simply distribute the QR code to other people (you can email, print, post to social media, do whatever you want)
Other people just download Blynk app, scan the code and…BOOM! - your app magically opens for them and it’s ready to use. They don’t even need to login or create an account.
Beta version is available for Android
(iOS version is in the development) and it’s free for 30 days. After that, it will be a paid service.
Download Blynk app for Android
Please keep in mind, that this is still an experimental feature with some limitations. We would love to hear your feedback and ideas.
We hope you’ll help us with catching some bugs as well wink emoticon
Yea man it has to be the easiest way to get up and running with a web connected product that you can easily share with others without the chance of them screwing it up!
@Escko Thanks! I had to modify the code to get it working but it does indeed work
It’s really awesome to be able to remotely see the serial print data on my phone from anywhere that I have a internet connection.
Here is the modified code to get it to run on the Photon.
Is there any way to resize the terminal widget size so I can see more of the incoming text? I can’t seem to change the size. The only thing I can do is choose to show or not show the input box for the terminal where no window gives you a little more room form incoming text.
I had to add this line of code to keep the Photon connected to the cloud because it was disconnecting after about 30 seconds because of the blocking “while loop in setup”. Adding “SYSTEM_THREAD(ENABLED)” fixed that.
* Blynk is a platform with iOS and Android apps to control
* Arduino, Raspberry Pi and the likes over the Internet.
* You can easily build graphic interfaces for all your
* projects by simply dragging and dropping widgets.
* Downloads, docs, tutorials: http://www.blynk.cc
* Blynk community: http://community.blynk.cc
* Social groups: http://www.fb.com/blynkapp
* http://twitter.com/blynk_app
* Blynk library is licensed under MIT license
* This example code is in public domain.
//#define BLYNK_DEBUG // Uncomment this to see debug prints
#define BLYNK_PRINT Serial
#include "blynk/BlynkSimpleParticle.h"
// You should get Auth Token in the Blynk App.
// Go to the Project Settings (nut icon).
char auth[] = "Enter Token Here";
// Attach a Button widget (mode: Switch) to the Digital pin 7 - and control the built-in blue led.
// Attach a Graph widget to Analog pin 1
// Attach a Gauge widget to Analog pin 2
// No coding is required for direct pin operations!// Attach virtual serial terminal to Virtual Pin V1
WidgetTerminal terminal(V1);
Blynk.begin(auth);
while (Blynk.connect() == false) {
// Wait until connected
// This will print Blynk Software version to the Terminal Widget when
// your hardware gets connected to Blynk Server
terminal.println(F("Blynk v" BLYNK_VERSION ": Device started"));
terminal.println("-------------");
terminal.println("Type 'Marco' and get a reply, or type");
terminal.println("anything else and get it printed back.");
terminal.flush();
// You can send commands from Terminal to your hardware. Just use
// the same Virtual Pin as your Terminal Widget
BLYNK_WRITE(V1)
// if you type "Marco" into Terminal Widget - it will respond: "Polo:"
if (String("Marco") == param.asStr()) {
terminal.println("You said: 'Marco'") ;
terminal.println("I said: 'Polo'") ;
} else {
// Send it back
terminal.print("You said:");
terminal.write(param.getBuffer(), param.getLength());
terminal.println();
// Ensure everything is sent
terminal.flush();
Blynk.run();
Hi, sorry for late reply. We have 2 different types of shared projects: cloning and sharing. The issue is that you are sharing or scanning not the right one: docs.blynk.cc/#sharing
