Bluetooth smart connection with photon
Hi, i would like to start a project in which a bluetooth device (in my case, an emotiv neuroheadset https://www.emotiv.com/epoc/1) could be connected to a photon device in order to transfer the sampled signals to it, and then process them. Does any of you experts know a bluetooth shield i could use with photon for this purpose? thanks
You could look into using Bluz or Redbear Duo, both working on the particle ecosystem and both offering Bluetooth capabilities.
Hi @Moors7, thanks for your answer … bluz was my first option, but it not suitable, since its is a BLE peripheral, and not a central … thanks
The gateway does act as a central, well… Gateway. Is has onboard wifi, allowing you to connect your Bluetooth devices to the Internet via it.
… yes, you are right. the Gateway could be a valid option. thanks @Moors7!
Great suggestion @Moors7! Let us know @fbt if this works out for you.
