I am trying to understand how best to change the device name that is seen when Pairing. On the P2 I am using I see that the default is of format PSeries-999999. Can this be simply read using String deviceName() const; and set using size_t appendLocalName(const String& name);? i.e. this is only relevant to Bluetooth?
Hey, on Argons and Borons I do exactly that.
e.g. for getting device name:
scanResult->advertisingData().deviceName()
best
I think what you are looking for is this in the DCT (configuration flash):
ssid prefix 1826 26
On the P2, it’s actually the whole BLE device name (DEVICE_NAME_DCT_OFFSET is an alias to the same DCT offset as DCT_SSID_PREFIX_OFFSET).
You can set this in DFU mode (alt=1), or you can set it from device firmware.
