BigNumber Library - anyone using with Photon/Particle devices?
Curious if anyone has experimented with the BigNumber library on the Particle devices? Mainly my concern is with RAM since that seemed to be an issue when I last used this library on ATmega1284.
Library reference:
http://forum.arduino.cc/index.php?topic=85692.0
I noticed that the SSL library for the Particle communication uses a multiple precision arithmetic library (firmware/communication/lib/tropicssl/library/bignum.c). Anyone familiar with this library and how it may compare to the Arduino ported one referenced above?
Anyone doing mathematical operations requiring large numbers too?
