I ordered a dozen mesh nodes, and I’m very excited about them! I want to drive some of them from batteries and have some questions.
- Do I need 3.7V batteries?
- What capacity should I look for if I want to make temperature measurements and send them to the cloud on a hourly basis for a year without recharging?
- How can I recharge the batteries? Simply recharge them via the mesh nodes while also connecting a USB charger to the nodes?
The Particle Mesh boards use 3.7V batteries just like other Feather boards.
A good source of 3.7V batteries is Adafruit.
I think you can just leave the battery connected to the mesh board and plug in a USB to recharge the battery.
I’m not sure exactly what capacity you would need to send readings at that frequency for that long.
That's ambitious
The mesh devices are intended to run much lower power than the current Particle devices, but a year of hourly waking without recharging may be challenging - also consider self-discharge of the LiPo in a year.
But to answer a bit more, we'd need to learn a bit more about your use-case.
- What sensor?
- What kind of uplink?
- How are the nodes linked?
- Does each node feater its own uplink?
- How long will the devices be awake each time?
However the answers to that, having empiric data usually beats even well educated guesses.
@nrobinson2000 Thank you for your answer! I think this is pretty much all I needed to know right now. Ordered two 1200mAh lipos.
@ScruffR I’ll use an MCP9808 with a Xenon. Not sure about the final network topology. The nodes will send the payload to InfluxDB databases. I don’t really insist to a one year uptime without charging after all, so I’ll see.
