I am new to photon boards and recently ordered the inventor’s kit from Sparkfun. I want to get a very simple project up and running, but want to make use of RTOS concepts. A basic “home-made” RTOS.
Is it possible to do the following
main()
/*init SW structures*/
/*init comms - setup wifi*/
/*init hw (gpios, I2C, etc)*/
/*if all OK, run the loop*/
/*loop - just to give an idea, not really while loop here*/
while(1)
/*read peripherals - based on interrupts/timers*/
/*process*/
/*post to web*/
Can I use the firmware libraries to do this? Where can I get access to main?
I have worked on similar projects with smaller micro controllers boards but this is the first time with a wifi.
FYI: I want to develop in C and have setup XCode as development platform.
Thank you.
