I have a project which was written using C++11 standard which works on both Windows and Raspberry Pi. Is it possible to use the same code (provided I have included all the required C++ libraries and handled all delays, threads, mutex, etc)
Is it possible to build the code in any other compiler and generate .bin file? Like VS2015, Arduino IDE, etc. Also is there a way to flash without using the Desktop IDE
I advise checking out the particle firmware repository @ https://github.com/spark/firmware. It features extensive documentation about building every part of the firmware stack. Also FreeRTOS is bundled somewhere in there as well.
For example You can link your application against the particle firmware build by soft linking your program source folder into https://github.com/spark/firmware/tree/develop/user/applications directory. For compilation you can just install the arm embedded toolchain @ https://launchpad.net/gcc-arm-embedded. The build system also has build in routines for flashing a particle device over USB with dfu-util.
Example command to compile a user application and flash it onto a photon:
demo@demopc:~/particle-firmware/main$ PLATFORM=photon APP=tinker make program-dfu
