[B523][DeviceOS 3.0.0] High current consumption during sleep
Short update - I have an almost identical E-Series based board with same onboard peripherals as the B5-SoM board. However, I am successful in setting the sleep modes on that board (both ULTRA_LOW_POWER and HIBERNATE).
In addition, setting the B-Series board to HIBERNATE gets the consumption down to 4,63 mA from ULTRA_LOW_POWER’s 4,97 mA.
If I placed the B523 in the eval board and run the following:
   // Initialize Power Configuration
   SystemSleepConfiguration measurementSleepConfig;
   // Ensure module is powered off.
   Cellular.off();
   delay(2000);
   // Power Configuration
   measurementSleepConfig.mode(SystemSleepMode::HIBERNATE);
   // Go to sleep
   SystemSleepResult result = System.sleep(measurementSleepConfig);
I see the following current consumption (30 mA?!)
with the following jumper setup (PMIC only)
