Sleep current for B523
Today I got the B523 module with the M.2 Evaluation Board in the mail. I hooked everything up, and see that the B523 alone is using around 20 mA in sleep mode. Is there any way to improve on this? it is a bit too much for running on batteries for some time. The device will wake up and publish data every 3 minutes. Test code below (with wakeup every 30 sec):
SystemSleepConfiguration config;
config.mode(SystemSleepMode::STOP)
      .gpio(D2, RISING)
      .duration(30s)
      .network(NETWORK_INTERFACE_CELLULAR);
SystemSleepResult result = System.sleep(config);
An upcoming version of Device OS will correct this. The B Series modules are not currently going into sleep mode properly which is causing excessive current consumption.
Ah! Good to hear. Any ETA on that? And what level of current can I expect when it releases? We are planning for 200 devices in October.
There should be a 2.0.0 release candidate with the fix in July. I believe around 20 uA in hibernate mode and 123 uA in stop mode sleep. These numbers aren’t final, but certainly much lower than 20 mA.
Ok, thanks. This makes it so much more interesting!
