Today, Particle.io Webhook integration with Azure IoT hub seems to work half way only.
It works great all the way up to the digital twins service which makes the integration with other complex IoT logic apps very easy.
Unfortunately it’s not possible to let the digital twin control the device via its corresponding device-twin in IoT hub.
Is this even possible, and if so, could you point me to any documentation on how to correctly setup the Azure IoT hub integration service ?
