I have a node.js solution that I’m deploying to AWS Lambda/Gateway API using Serverless.
For early testing I was using Axios and the API url: “https://api.particle.io/v1/products”
This worked fine. But I wanted to use the “particle-api-js” library, which is working great on my local pc.
But once deployed to lambda, the app crashes at the “require:”
const Particle = require("particle-api-js");
“require is not a function”
Has anyone else come across this? My other option is to create a container for all my particle functions, but I really want to use Serverless/Lambda as there’s other functions I want along side of these. And I’d prefer not to use the URL Api method if I could avoid it.
Thanks.
