Calling a particle function from a lambda function in aws
additionally how do i see how many publishes i have done of my free tier
What error are you getting?
How are you managing the Particle authentication token in the lambda function?
Are you using particle-api-js from your lambda function, or using the API directly?
What is the code in your lambda function (if you can share it)?
I couldn’t help myself… I had to ask Chat GPT this question. From what I know about calling functions it’s pretty good:
I asked:
How do I call a particle function from a lambda function in AWS
Chat GPT answered:
To call a Particle function from an AWS Lambda function, you need to make an HTTP request to the Particle Cloud API. Here's a step-by-step guide on how to do it:
  1. Set Up Particle Account and Device:
    • Ensure you have a Particle account and a Particle device (e.g., Photon, Argon) set up and connected.
    • Obtain the device ID and access token from the Particle Console.
  2. Create the Particle Function:
    • Define the function you want to call on your Particle device. This should be done in the firmware code.
    • For example:
      int myFunction(String command) {
          // Function implementation
          return 1;
          Particle.function("myFunction", myFunction);
  3. Set Up AWS Lambda:
    • Create an AWS Lambda function.
    • Configure the function with the appropriate permissions and roles to access the internet.
  4. Write the Lambda Function Code:
    • Use a programming language supported by AWS Lambda (e.g., Python, Node.js) to make an HTTP request to the Particle Cloud API.
    • Here's an example in Python using the requests library:
      import json
      import requests
      def lambda_handler(event, context):
          # Particle device details
          device_id = 'your_particle_device_id'
          access_token = 'your_particle_access_token'
          function_name = 'myFunction'
          command = 'your_command'
          # Particle API endpoint
          url = f'https://api.particle.io/v1/devices/{device_id}/{function_name}'
          # Request headers and payload
          headers = {
              'Authorization': f'Bearer {access_token}',
              'Content-Type': 'application/x-www-form-urlencoded'
          payload = {
              'arg': command
          # Make the HTTP POST request to call the Particle function
          response = requests.post(url, headers=headers, data=payload)
          # Handle the response
          if response.status_code == 200:
              result = response.json()
              return {
                  'statusCode': 200,
                  'body': json.dumps(result)
          else:
              return {
                  'statusCode': response.status_code,
                  'body': response.text
  5. Deploy and Test the Lambda Function:
    • Deploy your Lambda function in the AWS Management Console.
    • Test the function by invoking it manually or setting up a trigger (e.g., API Gateway, CloudWatch Events).
By following these steps, you can successfully call a Particle function from an AWS Lambda function.
