First, coming off of electric imp where there is a cloud agent and the device. I want to get a similar setup where I have a web page with a few buttons and status of the end point device. Where I am stuck. I have node on mac and the particle api installed, I have script relay.js that I can run and it will fire the web hook and my photon will get a cycleRelay. All good. I want that code on a webpage on a lightsail instance in amazon.
I have wordpress up there but i have installed the particle command line so I can particle … where I am currently stuck is running that same script on lightsail. When I attempt to install particle-api-js i get
npm WARN EBADENGINE Unsupported engine {
npm WARN EBADENGINE package: 'particle-api-js@9.4.1',
npm WARN EBADENGINE required: { node: '>=12.x', npm: '8.x' },
npm WARN EBADENGINE current: { node: 'v12.22.12', npm: '7.5.2' }
npm WARN EBADENGINE }
npm WARN deprecated formidable@1.2.6: Please upgrade to latest, formidable@v2 or formidable
@v3! Check these notes: https://bit.ly/2ZEqIau
npm WARN deprecated superagent@5.3.1: Please upgrade to v7.0.2+ of superagent. We have fix
ed numerous issues with streams, form-data, attach(), filesystem errors not bubbling up (EN
OENT on attach()), and all tests are now passing. See the releases tab for more informatio
n at <https://github.com/visionmedia/superagent/releases>.
npm WARN deprecated core-js@2.6.12: core-js@<3.23.3 is no longer maintained and not recomme
nded for usage due to the number of issues. Because of the V8 engine whims, feature detecti
on in old core-js versions could cause a slowdown up to 100x even if nothing is polyfilled.
Some versions have web compatibility issues. Please, upgrade your dependencies to the actu
al version of core-j
uname - a Linux ip-172-26-13-180 5.10.0-18-cloud-amd64 #1 SMP Debian 5.10.140-1 (2022-09-02) x86_64 G
NU/Linux
Fixing this will get node relay.js to work – this runs on my mac but not in light sail instance. Then I need a bit of help on the actual calling below.
My js looks like this for relay
var Particle = require('particle-api-js');
var particle = new Particle();
console.log ("loading function");
var fnPr = particle.callFunction({ deviceId: '33xxxxxxxxxxxxxxxxxxx4', name: 'Relay', arg
ument: 'cycle', auth: '4b7db2xxxxxxxxxxxxxx90eafxxx'});
fnPr.then(
function(data) {
console.log('Function called succesfully:', data);
}, function(err) {
console.log('An error occurred:', err);
Gives an error Cannot find module ‘particle-api-js’. I also cannot find it on the lightsail instance.
Second problem: Here is my simple HTML and JS for doing the webhook call on lightsail. I know a lot of languages but JS is not one of them. HTML
<!doctype html>
<html lang="en">
<head>
<meta charset="UTF-8">
<meta name="viewport" content="width=device-width, initial-scale=1.0">
<meta http-equiv="X-UA-Compatible" content="ie=edge">
<title>JavaScript Click Event Tutorial</title>
<link rel="stylesheet" href="index.css">
</head>
<body>
<p class="name">freeCodeCamp</p>
<button>Change color</button>
<script src="index.js"></script>
</body>
</html>
JS. - the comments in var lines where to test if the function was being called.
// Javascript
const name = document.querySelector(".name");
const button = document.querySelector("button");
var Particle = required('particle-api-js');
var Particle = new Particle();
var token;
console.log('loading function');
//button.addEventListener("click", function() {
//name.style.color = "blue";
button.addEventListener("click", function (){
name.style.color = "blue"; // change txt color on page to prove function is called. This works without the particle var at the top.
var ret = particle.callFunction({ deviceId: '3300xxxxxxxxxxxxxxx323334', name: 'Relay', argume
nt:'cycle', auth: '4b7db2cxxxxxxxxxxxxxxxxxxxxxxxx90eaf37'});
Again, I missed something when installing
