Automatic Setup for Windows firmware build/flash
After following this awesome tutorial video by @seulater, I figured it would be helpful to have these steps automated.
I created a Chocolatey package to auto install all the dependencies outlined on the firmware github readme.
The package is available in the chocolatey gallery. https://chocolatey.org/packages/sparkcore-build/
TL;DR and you know chocolately. Package name is sparkcore-build.
Longer version
If you’re a windows user and you don’t know chocolatey, you’re missing out!
To install chocolatey just run this at a command prompt (their instructions) …
@powershell -NoProfile -ExecutionPolicy unrestricted -Command "iex ((new-object net.webclient).DownloadString('https://chocolatey.org/install.ps1'))" && SET PATH=%PATH%;%systemdrive%\chocolatey\bin
then to install all the SparkCore build dependencies…
cinst sparkcore-build
That’s it! This covers all of section 1(Download and Install Dependencies) from the instructions.
Now you can skip straight down to section 2(Download and Build Repositories).
There were a couple of issues with the Make and Zadig packages. All corrected now.
To update…
cup sparkcore-build
I get choco errrors on
gcc-arm v4.8.1
Write-Error : gcc-arm did not finish successfully. Boo to
the chocolatey gods!
[ERROR] Exception calling “GetResponse” with
"0" argument(s): "The underlying c
onnection was closed: An unexpected error occurred on a
send."
At C:\Documents and Settings\All Users\Application
Data\chocolatey\chocolateyin
stall\helpers\functions\Write-ChocolateyFailure.ps1:30
char:14
  • Write-Error
    <<<< $errorMessage
CategoryInfo : NotSpecified:
(:slight_smile: [Write-Error], WriteErrorExcep
tion
+ FullyQualifiedErrorId
: Microsoft.PowerShell.Commands.WriteErrorExceptio
n,Write-Error
Write-Error : Package ‘gcc-arm v4.8.1’ did not install
successfully: Exception
calling “GetResponse” with "0"
argument(s): "The underlying connection was clos
ed: An unexpected error occurred on a send."
stall\functions\Chocolatey-NuGet.ps1:90 char:28
Write-Error <<<<
"Package `’$installedPackageName v$installe
dPackageVersion`’ did not install successfully:
$($_.Exception.Message)"
tion
AND
dfu-util v0.7.1
Write-Error : dfu-util did not finish successfully. Boo to
"0" argument(s): "The remote name
could not be resolved: ‘dfu-util.gnumonks.org’"
char:14
  • Write-Error
    <<<< $errorMessage
tion
FullyQualifiedErrorId : Microsoft.PowerShell.Commands.WriteErrorExceptio
n,Write-Error
Write-Error : Package ‘dfu-util v0.7.1’ did not install
calling
"GetResponse" with “0” argument(s): "The remote name
could not be reso
Write-Error <<<<
tion
