Local toolchain issue [SOLVED]
I haven’t used my cores in a few weeks. Just grabbed the latest from the repo’s but I cannot make the project, even as-is from the repo.
I’m pretty sure I haven’t changed anything. Below is the error/output. :-/
make clean all
rm -f  obj/src/application.o obj/src/main.o obj/src/newlib_stubs.o obj/src/spark_utilities.o obj/src/spark_wiring.o obj/src/spark_wiring_i2c.o obj/src/spark_wiring_interrupts.o obj/src/spark_wiring_ipaddress.o obj/src/spark_wiring_network.o obj/src/spark_wiring_print.o obj/src/spark_wiring_servo.o obj/src/spark_wiring_spi.o obj/src/spark_wiring_stream.o obj/src/spark_wiring_string.o obj/src/spark_wiring_tcpclient.o obj/src/spark_wiring_tcpserver.o obj/src/spark_wiring_time.o obj/src/spark_wiring_udp.o obj/src/spark_wiring_usartserial.o obj/src/spark_wiring_usbserial.o obj/src/spark_wiring_wifi.o obj/src/spark_wlan.o obj/src/stm32_it.o obj/src/usb_desc.o obj/src/usb_endp.o obj/src/usb_istr.o obj/src/usb_prop.o obj/src/wifi_credentials_reader.o obj/startup/startup_stm32f10x_md.o  obj/src/application.o.d obj/src/main.o.d obj/src/newlib_stubs.o.d obj/src/spark_utilities.o.d obj/src/spark_wiring.o.d obj/src/spark_wiring_i2c.o.d obj/src/spark_wiring_interrupts.o.d obj/src/spark_wiring_ipaddress.o.d obj/src/spark_wiring_network.o.d obj/src/spark_wiring_print.o.d obj/src/spark_wiring_servo.o.d obj/src/spark_wiring_spi.o.d obj/src/spark_wiring_stream.o.d obj/src/spark_wiring_string.o.d obj/src/spark_wiring_tcpclient.o.d obj/src/spark_wiring_tcpserver.o.d obj/src/spark_wiring_time.o.d obj/src/spark_wiring_udp.o.d obj/src/spark_wiring_usartserial.o.d obj/src/spark_wiring_usbserial.o.d obj/src/spark_wiring_wifi.o.d obj/src/spark_wlan.o.d obj/src/stm32_it.o.d obj/src/usb_desc.o.d obj/src/usb_endp.o.d obj/src/usb_istr.o.d obj/src/usb_prop.o.d obj/src/wifi_credentials_reader.o.d obj/startup/startup_stm32f10x_md.o.d core-firmware.elf core-firmware.bin core-firmware.hex core-firmware.map
Clean core-common-lib
rm -f obj/CC3000_Host_Driver/cc3000_common.o obj/CC3000_Host_Driver/evnt_handler.o obj/CC3000_Host_Driver/hci.o obj/CC3000_Host_Driver/netapp.o obj/CC3000_Host_Driver/nvmem.o obj/CC3000_Host_Driver/security.o obj/CC3000_Host_Driver/socket.o obj/CC3000_Host_Driver/wlan.o obj/SPARK_Firmware_Driver/src/cc3000_spi.o obj/SPARK_Firmware_Driver/src/hw_config.o obj/SPARK_Firmware_Driver/src/sst25vf_spi.o obj/SPARK_Firmware_Driver/src/system_stm32f10x.o obj/SPARK_Firmware_Driver/src/usb_pwr.o obj/SPARK_Firmware_Driver/src/debug.o obj/SPARK_Firmware_Driver/src/panic.o obj/STM32F10x_StdPeriph_Driver/src/misc.o obj/STM32F10x_StdPeriph_Driver/src/stm32f10x_adc.o obj/STM32F10x_StdPeriph_Driver/src/stm32f10x_bkp.o obj/STM32F10x_StdPeriph_Driver/src/stm32f10x_crc.o obj/STM32F10x_StdPeriph_Driver/src/stm32f10x_dma.o obj/STM32F10x_StdPeriph_Driver/src/stm32f10x_exti.o obj/STM32F10x_StdPeriph_Driver/src/stm32f10x_flash.o obj/STM32F10x_StdPeriph_Driver/src/stm32f10x_gpio.o obj/STM32F10x_StdPeriph_Driver/src/stm32f10x_i2c.o obj/STM32F10x_StdPeriph_Driver/src/stm32f10x_iwdg.o obj/STM32F10x_StdPeriph_Driver/src/stm32f10x_pwr.o obj/STM32F10x_StdPeriph_Driver/src/stm32f10x_rcc.o obj/STM32F10x_StdPeriph_Driver/src/stm32f10x_rtc.o obj/STM32F10x_StdPeriph_Driver/src/stm32f10x_spi.o obj/STM32F10x_StdPeriph_Driver/src/stm32f10x_tim.o obj/STM32F10x_StdPeriph_Driver/src/stm32f10x_usart.o obj/STM32_USB-FS-Device_Driver/src/usb_core.o obj/STM32_USB-FS-Device_Driver/src/usb_init.o obj/STM32_USB-FS-Device_Driver/src/usb_int.o obj/STM32_USB-FS-Device_Driver/src/usb_mem.o obj/STM32_USB-FS-Device_Driver/src/usb_regs.o obj/STM32_USB-FS-Device_Driver/src/usb_sil.o   obj/CC3000_Host_Driver/cc3000_common.o.d obj/CC3000_Host_Driver/evnt_handler.o.d obj/CC3000_Host_Driver/hci.o.d obj/CC3000_Host_Driver/netapp.o.d obj/CC3000_Host_Driver/nvmem.o.d obj/CC3000_Host_Driver/security.o.d obj/CC3000_Host_Driver/socket.o.d obj/CC3000_Host_Driver/wlan.o.d obj/SPARK_Firmware_Driver/src/cc3000_spi.o.d obj/SPARK_Firmware_Driver/src/hw_config.o.d obj/SPARK_Firmware_Driver/src/sst25vf_spi.o.d obj/SPARK_Firmware_Driver/src/system_stm32f10x.o.d obj/SPARK_Firmware_Driver/src/usb_pwr.o.d obj/SPARK_Firmware_Driver/src/debug.o.d obj/SPARK_Firmware_Driver/src/panic.o.d obj/STM32F10x_StdPeriph_Driver/src/misc.o.d obj/STM32F10x_StdPeriph_Driver/src/stm32f10x_adc.o.d obj/STM32F10x_StdPeriph_Driver/src/stm32f10x_bkp.o.d obj/STM32F10x_StdPeriph_Driver/src/stm32f10x_crc.o.d obj/STM32F10x_StdPeriph_Driver/src/stm32f10x_dma.o.d obj/STM32F10x_StdPeriph_Driver/src/stm32f10x_exti.o.d obj/STM32F10x_StdPeriph_Driver/src/stm32f10x_flash.o.d obj/STM32F10x_StdPeriph_Driver/src/stm32f10x_gpio.o.d obj/STM32F10x_StdPeriph_Driver/src/stm32f10x_i2c.o.d obj/STM32F10x_StdPeriph_Driver/src/stm32f10x_iwdg.o.d obj/STM32F10x_StdPeriph_Driver/src/stm32f10x_pwr.o.d obj/STM32F10x_StdPeriph_Driver/src/stm32f10x_rcc.o.d obj/STM32F10x_StdPeriph_Driver/src/stm32f10x_rtc.o.d obj/STM32F10x_StdPeriph_Driver/src/stm32f10x_spi.o.d obj/STM32F10x_StdPeriph_Driver/src/stm32f10x_tim.o.d obj/STM32F10x_StdPeriph_Driver/src/stm32f10x_usart.o.d obj/STM32_USB-FS-Device_Driver/src/usb_core.o.d obj/STM32_USB-FS-Device_Driver/src/usb_init.o.d obj/STM32_USB-FS-Device_Driver/src/usb_int.o.d obj/STM32_USB-FS-Device_Driver/src/usb_mem.o.d obj/STM32_USB-FS-Device_Driver/src/usb_regs.o.d obj/STM32_USB-FS-Device_Driver/src/usb_sil.o.d   libcore-common-lib.a
Clean core-communication-lib
rm -f obj/lib/tropicssl/library/aes.o obj/lib/tropicssl/library/bignum.o obj/lib/tropicssl/library/padlock.o obj/lib/tropicssl/library/rsa.o obj/lib/tropicssl/library/sha1.o obj/src/coap.o obj/src/handshake.o obj/src/spark_protocol.o obj/src/events.o  obj/lib/tropicssl/library/aes.o.d obj/lib/tropicssl/library/bignum.o.d obj/lib/tropicssl/library/padlock.o.d obj/lib/tropicssl/library/rsa.o.d obj/lib/tropicssl/library/sha1.o.d obj/src/coap.o.d obj/src/handshake.o.d obj/src/spark_protocol.o.d obj/src/events.o.d  libcore-communication-lib.a
Building core-common-lib
Building file: ../CC3000_Host_Driver/cc3000_common.c
Invoking: ARM GCC C Compiler
mkdir -p obj/CC3000_Host_Driver/
arm-none-eabi-gcc -g3 -gdwarf-2 -Os -mcpu=cortex-m3 -mthumb  -I../CC3000_Host_Driver -I../SPARK_Firmware_Driver/inc -I../STM32F10x_StdPeriph_Driver/inc -I../STM32_USB-FS-Device_Driver/inc -I../CMSIS/Include -I../CMSIS/Device/ST/STM32F10x/Include -I. -ffunction-sections -Wall -Wno-switch -fmessage-length=0 -MD -MP -MF obj/CC3000_Host_Driver/cc3000_common.o.d -DUSE_STDPERIPH_DRIVER -DSTM32F10X_MD -DRELEASE_BUILD -c -o obj/CC3000_Host_Driver/cc3000_common.o ../CC3000_Host_Driver/cc3000_common.c
make[1]: arm-none-eabi-gcc: No such file or directory
make[1]: *** [obj/CC3000_Host_Driver/cc3000_common.o] Error 1
make: *** [check_external_deps] Error 2
Hi @dermotos
It looks like gcc is no longer on the path. What happens if you type which arm-none-eabi-gcc in the shell where you do the make? That should return the path to the gcc cross compiler.
Nothing happens
Dermots-iMac:build dermotos$ which arm-none-eabi-gcc
Ok, it was definitely removed from my path. I’m guessing it was caused by installing the pebble SDK. Grrr…
Anyways, If I edit my path as described here: http://architectryan.com/2012/10/02/add-to-the-path-on-mac-os-x-mountain-lion/#.UzLMR62SzYc
It doesn’t seem to make any difference. If I run the below command:
export PATH="$PATH:/usr/local/gcc_arm/gcc-arm-none-eabi-4_7-2013q3/bin/"
It will work until I close my terminal window, after that it doesn’t work again. How can I edit my path so it stays working?
Thanks! :smile:
Edit: Got it! I thought the export command was editing my path, rather than just for the current session. Added it to my ~/.bash_profile and its working now. Thanks for pointing me in the right direction.
@bko, I’m getting a similar, shorter error:
Mine is only about not being able to find cc3000_common.o. The [check_external_deps] is also present, which means both are Error 2.
I was checking out compiling through the command line for the first time.
Is there a way to solve this?
*C:\Users\Admin\Documents\core-firmware\build>make
Building file: …/CC3000_Host_Driver/cc3000_common.c
arm-none-eabi-gcc -g3 -gdwarf-2 -Os -mcpu=cortex-m3 -mthumb -I…/CC3000_Host_Dr
iver -I…/SPARK_Firmware_Driver/inc -I…/STM32_USB-FS-Device_Driver/inc -I…/STM
32F10x_StdPeriph_Driver/inc -I…/CMSIS/Include -I…/CMSIS/Device/ST/STM32F10x/In
RELEASE_BUILD -c -o obj/CC3000_Host_Driver/cc3000_common.o …/CC3000_Host_Driver
/cc3000_common.c
process_begin: CreateProcess(NULL, arm-none-eabi-gcc -g3 -gdwarf-2 -Os -mcpu=cor
tex-m3 -mthumb -I…/CC3000_Host_Driver -I…/SPARK_Firmware_Driver/inc -I…/STM32
USB-FS-Device_Driver/inc -I…/STM32F10x_StdPeriph_Driver/inc -I…/CMSIS/Include
-I…/CMSIS/Device/ST/STM32F10x/Include -I. -ffunction-sections -Wall -Wno-switc
000_common.o …/CC3000_Host_Driver/cc3000_common.c, …) failed.
make (e=2): The system cannot find the file specified.
make[1]: *** *[obj/CC3000_Host_Driver/cc3000_common.o] Error 2
Hi @LIGHThouse
I think you do not have all three repos needed to do the local build. You should have core-firmware, core-common-lib, and core-communication-lib. Then in core-firmware/build, when you type make or make clean all you will build all three.
Instructions are here:
Hi, @bko!
I’d ensured that I had all repos in the same directory before building. I tried to restart the entire process from scratch but I’m still getting the same error.
When I navigate to core-common-lib > build > obj on Windows Explorer, I find CC3000_Host_Driver to be empty. I think that’s where the error is; not being able to find cc3000_common.o.
I read the instructions a few times. I’m not able to find anything different in what I’m trying to do.
These are my errors:
Microsoft Windows [Version 6.1.7601]
Copyright © 2009 Microsoft Corporation. All rights reserved.
C:\Users\Admin>cd /
C:>ls
$Recycle.Bin Program Files Windows
ATI Program Files (x86) hiberfil.sys
Bluegiga ProgramData opencv
Dell Python27 pagefile.sys
Documents and Settings Recovery temp
END Spark user.js
MSOCache System Volume Information
PerfLogs Users
C:>cd Spark
C:\Spark>ls
core-common-lib core-communication-lib core-firmware
C:\Spark>cd core-firmware
C:\Spark\core-firmware>cd build
C:\Spark\core-firmware\build>make clean all
utilities.o obj/src/spark_wiring.o obj/src/spark_wiring_eeprom.o obj/src/spark
o obj/src/spark_wiring_time.o obj/src/spark_wiring_tone.o obj/src/spark_wiring_u
g.o.d obj/src/spark_wiring_eeprom.o.d obj/src/spark_wiring_i2c.o.d obj/src/spark
src/spark_wiring_time.o.d obj/src/spark_wiring_tone.o.d obj/src/spark_wiring_udp
ic.o obj/STM32_USB-FS-Device_Driver/src/usb_core.o obj/STM32_USB-FS-Device_Drive
32_USB-FS-Device_Driver/src/usb_sil.o obj/STM32F10x_StdPeriph_Driver/src/misc.o
bj/STM32F10x_StdPeriph_Driver/src/stm32f10x_usart.o obj/CC3000_Host_Driver/cc3
obj/STM32_USB-FS-Device_Driver/src/usb_sil.o.d obj/STM32F10x_StdPeriph_Driver/s
10x_usart.o.d libcore-common-lib.a
/cc3000_common.c
make[1]: *** [obj/CC3000_Host_Driver/cc3000_common.o] Error 2
I'm getting the same like @LIGHThouse :
iver -I../SPARK_Firmware_Driver/inc -I../STM32_USB-FS-Device_Driver/inc -I../STM
32F10x_StdPeriph_Driver/inc -I../CMSIS/Include -I../CMSIS/Device/ST/STM32F10x/In
/cc3000_common.c
USB-FS-Device_Driver/inc -I../STM32F10x_StdPeriph_Driver/inc -I../CMSIS/Include
000_common.o ../CC3000_Host_Driver/cc3000_common.c, ...) failed.
Anyone?
Hi @itayd100
You should make sure you have all three repositories, core-firmware, core-communication-lib and core-common-lib in three directories all contained in the same directory and then in the core-firmware\build directory do:
make clean all
the first time.
Hi @bko , thank you for helping me.
All three directories inside c:\spark. I did what you said and I got this:
bj/src/spark_wiring_tone.o obj/src/spark_wiring_udp.o obj/src/spark_wiring_usart
d obj/src/spark_utilities.o.d obj/src/spark_wiring.o.d obj/src/spark_wiring_eepr
om.o.d obj/src/spark_wiring_i2c.o.d obj/src/spark_wiring_interrupts.o.d obj/src/
spark_wiring_ipaddress.o.d obj/src/spark_wiring_print.o.d obj/src/spark_wiring_s
pserver.o.d obj/src/spark_wiring_time.o.d obj/src/spark_wiring_tone.o.d obj/src/
ic.o obj/SPARK_Firmware_Driver/src/spi_bus.o obj/STM32_USB-FS-Device_Driver/src/
10x_usart.o obj/CC3000_Host_Driver/cc3000_common.o.d obj/CC3000_Host_Driver/ev
.d obj/SPARK_Firmware_Driver/src/panic.o.d obj/SPARK_Firmware_Driver/src/spi_bus
.d obj/STM32_USB-FS-Device_Driver/src/usb_sil.o.d obj/STM32F10x_StdPeriph_Driver
2f10x_usart.o.d libcore-common-lib.a
/cc3000_common.c
Still not working... Do you have any idea?
@itayd100 can you open a cmd prompt and type “make” and see what it says
@Hootie81, here what i see:
/cc3000_common.c
Sorry for the delay… did you install GCC?
link is on this page…
@Hootie81 @bko
The path was the problem :frowning:
Now everything is good.
Thank for your responses.
Itay
Awesome, was it the GCC path?
GNU Tools ARM Embedded, I needed to change the 2013–>2014 & q1–>q2.
path: C:\SparkCorePrograms\GNU Tools ARM Embedded\4.8 2014q2\bin.
BTW, do you know how can I use the Spark.Function and the include a library (Time for example) there?
Hi @itayd100
Time is built-in now. See this doc:
http://docs.spark.io/firmware/#libraries-time
@bko thanks!!
Now I’m going to try debugging…
Hi @bko I have a similar issue here, hoping you can help.
I have been compiling code for spark on my win 8 machine successfully until i installed ride7 compiler for another project. Ride 7 also uses the same arm-none-eabi-gcc compiler.
When I type ‘which arm-none-eabi-gcc’ I get
/cygdrive/c/Program Files (x86)/Raisonance/Ride/arm-gcc/bin/arm-none-eabi-gcc
I have edited \core-firmware\build\make.mk as follows but with no success…
# Define the compiler/tools prefix
GCC_PREFIX ?= C:\SparkPrograms\GNU Tools ARM Embedded\4.9 2014q4\bin\arm-none-eabi-
# Define tools
CC = $(GCC_PREFIX)gcc
CPP = $(GCC_PREFIX)g++
AR = $(GCC_PREFIX)ar
OBJCOPY = $(GCC_PREFIX)objcopy
SIZE = $(GCC_PREFIX)size
DFU = dfu-util
DFUSUFFIX = dfu-suffix
CURL = curl
RM = rm -f
RMDIR = rm -f -r
MKDIR = mkdir -p
I don’t want to uninstall ride7.
Any suggestions???
Many Thanks in advance
I think you just want to point to the bin directory and let the links below figure everything out, but I am away from a computer where I could test this.
You might also want to try just changing the windows search path in the shell you use for Spark to put the Spark version of the compiler ahead on the path:
set PATH="C:\SparkPrograms\GNU Tools ARM Embedded\4.9 2014q4\bin\;%PATH%"
If you put this in a batch file, you can just run that before you start working on Spark in that shell. The change will work in that cmd shell until you close it.
