Building Particle Firmware on Windows
Hi there. I’m having trouble with the instructions here:
…at the stage where I’m running:
make clean all PLATFORM=electron -s program-dfu
It’s falling over in arm-tools.mk at the line:
arm_gcc_version:=$(shell $(CC) --version | head -n 1)
The | obviously isn’t going to work on Windows, so I’m wondering if this has to be run under Cygwin? I have tried commenting the relevant lines out (since it’s only a compiler version check), but then I hit:
test: echo: binary operator expected
…so I’m obviously doing something fundamentally wrong. FYI, I have GCC, Make, etc. installed and there are no spaces in paths.
This thread might be of use: Local toolchain with Windows [SOLVED]
