attachInterrupt() cause to hard fault
Hi everyone,
I need to declare 3 interrupts in my firmware
1 - on pin P1S1
2 - on pin P1S2
3 - on pin TX (#64)
The first two interrupt are working well, but when I tried to add the 3rd interrupt, it caused to a hard fault.
I am pretty sure that it’s not related to syntax because I used interrupts before and it worked well.
maybe it’s related to this pice information in the particle reference:
1
Fan.h:
#include "Particle.h"
#define FAN_PIN        RX
#define FAN_TACHO      TX
#define INIT_FAN_VALUE 255  //off
class Fan
private:
    uint8_t fanSpeed;
    void ISRfunc();
public:
    Fan();
    void setup();
    void run();
    void run(uint8_t);
    void setFanSpeed(uint8_t);
Fan.cpp:
#include "Fan.h"
Fan::Fan()
    this->setFanSpeed(INIT_FAN_VALUE);
void Fan::setup()
    pinMode(FAN_PIN, OUTPUT);
    this->run();
    pinMode(FAN_TACHO, INPUT);
    attachInterrupt(FAN_TACHO, &Fan::ISRfunc, this, CHANGE);
void Fan::run()
    analogWrite(FAN_PIN, this->fanSpeed);
void Fan::run(uint8_t fanSpeed)
    if (fanSpeed > 255 || fanSpeed < 0)
        return;
    analogWrite(FAN_PIN, fanSpeed);
void Fan::setFanSpeed(uint8_t fanSpeed)
    if (fanSpeed <= 255 || fanSpeed >= 0)
        this->fanSpeed = fanSpeed;
void Fan::ISRfunc()
    Particle.publish("test", "*#*#*#*");
    delay(200);
I hope that someone can help me with this issue soon.
Thanks in advance,
Omri
@Omri, you shouldn’t be doing a Particle.publish() within an ISR. Nor should you have a delay() as millis() don’t run in an ISR and it could block other interrupts for the duration. Rember that ISR’s need to be lite and fast. For your ISR, you should set a flag or increment a counter that you test and handle in loop().
@peekay123, Thank you very much!!!
I did delete the Particle.publish and it’s work now.
