Hello, I just opened a very old Argon. I am unable to get it to connect to cloud. Below are some of the logs. I've tried flashing via the cli and web. I've tried using the device doctor and the device restore. It says it's updating the NCP, but it always shows version 3, never 5. I don't know what to do next. I have another argon that is working fine. Can someone take a look and suggest next steps?
C:\Users\Roberto\Downloads>particle flash --serial argon-ncp-firmware-0.0.5-ota.bin
NOTE: particle flash serial has been replaced by particle flash --local.
Please use that command going forward.
Flashing argon e00fce68035f29ecfb08fb06
[█████████████████████████] 100% | Flash success!
C:\Users\Roberto\Downloads>particle flash --local argon-ncp-firmware-0.0.5-ota.bin
C:\Users\Roberto\Downloads>particle serial inspect
Device: e00fce68035f29ecfb08fb06
Platform: 12 - Argon
Modules
Bootloader module #0 - version 3300
Size: 48.578 kB / MaxSize: 49.152 kB
Integrity: PASS
Address Range: PASS
Platform: PASS
Dependencies: PASS
System part module #1 - version 6400
Size: 538.624 kB / MaxSize: 573.44 kB
Integrity: PASS
Address Range: PASS
Platform: PASS
Dependencies: PASS
Radio stack module module #0 - version 202
Bootloader module #0 - version 3100
User part module #2 - version 10
Size: 34.242 kB / MaxSize: 262.144 kB
UUID: 2b38d91cfdcad8c08f7f9be4deed0f774d5f44fbc325abafe6647b85b94bfe1b
Integrity: PASS
Address Range: PASS
Platform: PASS
Dependencies: PASS
Network co-processor firmware module #0 - version 3
Size: 0 kB / MaxSize: 1536 kB
Integrity: PASS
Address Range: PASS
Platform: PASS
Dependencies: PASS
Size: 0 kB / MaxSize: 155.648 kB
Integrity: PASS
Address Range: PASS
Platform: PASS
Dependencies: PASS
C:\Users\Roberto\Downloads>particle serial monitor --follow
Polling for available serial device...Opening serial monitor for com port: " COM3 "
Serial monitor opened successfully:
0000065522 [ncp.esp32.at] TRACE: < +CWLAP:(3,"LOLiveGarden",-44,"84:d8:1b:7a:3a:ee",7)
0000065523 [ncp.esp32.at] TRACE: < +CWLAP:(3,"LOLiveGarden",-56,"d8:07:b6:71:90:16",7)
0000065525 [ncp.esp32.at] TRACE: < +CWLAP:(3,"",-58,"de:07:b6:71:90:16",7)
0000065526 [ncp.esp32.at] TRACE: < +CWLAP:(3,"",-68,"5c:d9:98:5a:b5:ae",11)
0000065527 [ncp.esp32.at] TRACE: < +CWLAP:(3,"DIRECT-roku-185",-69,"b8:3e:59:d4:77:0d",11)
0000065528 [ncp.esp32.at] TRACE: < +CWLAP:(3,"",-70,"8a:d8:1b:7a:3a:f2",7)
0000065530 [ncp.esp32.at] TRACE: < +CWLAP:(3,"",-71,"de:07:b6:71:90:12",7)
0000065531 [ncp.esp32.at] TRACE: < +CWLAP:(3,"LOLiveGarden",-72,"d8:07:b6:71:90:12",7)
0000065532 [ncp.esp32.at] TRACE: < +CWLAP:(3,"Rose Garden",-75,"72:13:01:3e:c5:e1",11)
0000065534 [ncp.esp32.at] TRACE: < +CWLAP:(5,"",-75,"72:13:01:3e:c5:e6",11)
0000065535 [ncp.esp32.at] TRACE: < +CWLAP:(3,"Fios-bL2rH-IoT",-82,"6a:f8:53:b0:d6:10",1)
0000065536 [ncp.esp32.at] TRACE: < +CWLAP:(3,"meshing-around",-83,"b0:e4:d5:8a:11:b3",11)
0000065538 [ncp.esp32.at] TRACE: < +CWLAP:(3,"Rosado's",-93,"24:05:88:43:1e:3e",11)
0000065539 [ncp.esp32.at] TRACE: < OK
0000065540 [ncp.esp32.client] TRACE: Connecting to "LOLiveGarden"
0000068557 [ncp.esp32.at] TRACE: < WIFI CONNECTED
0000069402 [ncp.esp32.at] TRACE: < OK
0000069403 [ncp.esp32.client] TRACE: NCP connection state changed: 2
0000069404 [net.esp32ncp] TRACE: NCP event 2
0000069404 [net.esp32ncp] TRACE: State changed event: 2
0000069405 [ncp.esp32.at] TRACE: > AT+CWJAP?
0000069407 [ncp.esp32.at] TRACE: < +CWJAP:"LOLiveGarden","84:d8:1b:7a:3a:ee",7,-44
0000069409 [ncp.esp32.at] TRACE: < OK
0000069409 [net.ifapi] INFO: Netif wl3 link UP, profile=LOLiveGarden
0000069413 [ncp.esp32.client] ERROR: Failed to write into data channel -60001
0000069414 [system.nm] INFO: State changed: IFACE_UP -> IFACE_LINK_UP
0000069415 [net.esp32ncp] TRACE: NCP event 3
0000069416 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_DOWN
0000069417 [system.nm] TRACE: Interface 4 power state changed: POWERING_DOWN
0000069418 [net.esp32ncp] TRACE: NCP event 3
0000069418 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_DOWN
0000069419 [system.nm] TRACE: Interface 4 power state changed: DOWN
0000069420 [ncp.esp32.client] TRACE: NCP connection state changed: 0
0000069421 [net.esp32ncp] TRACE: NCP event 2
0000069422 [net.esp32ncp] TRACE: State changed event: 0
0000069423 [net.ifapi] INFO: Netif wl3 link DOWN, profile=NONE
0000069423 [hal] INFO: DNS server list changed
0000069424 [hal] INFO: DNS server list changed
0000069428 [system.nm] INFO: State changed: IFACE_LINK_UP -> IFACE_UP
0000069429 [ncp.esp32.client] TRACE: NCP state changed: 0
0000069429 [net.esp32ncp] TRACE: NCP event 1
0000069430 [ncp.esp32.client] TRACE: Deinit modem serial.
0000069530 [net.esp32ncp] TRACE: NCP event 3
0000069531 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
0000069532 [system.nm] TRACE: Interface 4 power state changed: POWERING_UP
0000070833 [ncp.esp32.at] TRACE: > AT
0000070835 [ncp.esp32.at] TRACE: < OK
0000071835 [ncp.esp32.client] TRACE: NCP ready to accept AT commands
0000071836 [ncp.esp32.at] TRACE: > AT+MVER
0000071837 [ncp.esp32.at] TRACE: < 3
0000071838 [ncp.esp32.at] TRACE: < OK
0000071839 [ncp.esp32.at] TRACE: > AT+GETMAC=0
0000071840 [ncp.esp32.at] TRACE: < +GETMAC: "30:ae:a4:d1:78:10"
0000071841 [ncp.esp32.at] TRACE: < OK
0000071843 [ncp.esp32.at] TRACE: > AT+CWDHCP=0,3
0000071846 [ncp.esp32.at] TRACE: < OK
0000071847 [ncp.esp32.client] TRACE: NCP state changed: 1
0000071848 [net.esp32ncp] TRACE: NCP event 1
0000071848 [net.esp32ncp] TRACE: NCP event 3
0000071849 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_UP
0000071850 [system.nm] TRACE: Interface 4 power state changed: UP
0000071854 [ncp.esp32.at] TRACE: > AT+CWLAP
0000074358 [ncp.esp32.at] TRACE: < +CWLAP:(3,"LOLiveGarden",-44,"84:d8:1b:7a:3a:ee",7)
0000074359 [ncp.esp32.at] TRACE: < +CWLAP:(3,"",-44,"8a:d8:1b:7a:3a:ee",7)
0000074361 [ncp.esp32.at] TRACE: < +CWLAP:(3,"LOLiveGarden",-57,"d8:07:b6:71:90:16",7)
0000074362 [ncp.esp32.at] TRACE: < +CWLAP:(3,"LOLiveGarden",-68,"84:d8:1b:7a:3a:f2",7)
0000074363 [ncp.esp32.at] TRACE: < +CWLAP:(3,"",-68,"de:07:b6:71:90:12",7)
0000074364 [ncp.esp32.at] TRACE: < +CWLAP:(3,"LOLiveGarden",-70,"d8:07:b6:71:90:12",7)
0000074366 [ncp.esp32.at] TRACE: < +CWLAP:(3,"",-70,"8a:d8:1b:7a:3a:f2",7)
0000074367 [ncp.esp32.at] TRACE: < +CWLAP:(3,"",-70,"5c:d9:98:5a:b5:ae",11)
0000074368 [ncp.esp32.at] TRACE: < +CWLAP:(3,"",-70,"b8:3e:59:d4:77:0d",11)
0000074369 [ncp.esp32.at] TRACE: < +CWLAP:(3,"Rose Garden",-74,"72:13:01:3e:c5:e1",11)
0000074371 [ncp.esp32.at] TRACE: < +CWLAP:(3,"Fios-bL2rH",-82,"b8:f8:53:b0:d6:16",1)
0000074372 [ncp.esp32.at] TRACE: < +CWLAP:(3,"Fios-bL2rH-IoT",-83,"6a:f8:53:b0:d6:10",1)
0000074374 [ncp.esp32.at] TRACE: < +CWLAP:(3,"Fios-BootsW",-92,"b8:f8:53:f4:6f:1a",1)
0000074375 [ncp.esp32.at] TRACE: < +CWLAP:(3,"",-95,"6c:c3:74:e2:a1:2c",1)
0000074376 [ncp.esp32.at] TRACE: < OK
0000074377 [ncp.esp32.client] TRACE: Connecting to "LOLiveGarden"
0000077383 [ncp.esp32.at] TRACE: < WIFI CONNECTED
0000078217 [ncp.esp32.at] TRACE: < OK
0000078218 [ncp.esp32.client] TRACE: NCP connection state changed: 2
0000078219 [net.esp32ncp] TRACE: NCP event 2
0000078219 [net.esp32ncp] TRACE: State changed event: 2
0000078220 [ncp.esp32.at] TRACE: > AT+CWJAP?
0000078223 [ncp.esp32.at] TRACE: < +CWJAP:"LOLiveGarden","84:d8:1b:7a:3a:ee",7,-40
0000078224 [ncp.esp32.at] TRACE: < OK
0000078224 [net.ifapi] INFO: Netif wl3 link UP, profile=LOLiveGarden
0000078228 [ncp.esp32.client] ERROR: Failed to write into data channel -60001
0000078229 [system.nm] INFO: State changed: IFACE_UP -> IFACE_LINK_UP
0000078230 [net.esp32ncp] TRACE: NCP event 3
0000078231 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_DOWN
0000078232 [system.nm] TRACE: Interface 4 power state changed: POWERING_DOWN
0000078233 [net.esp32ncp] TRACE: NCP event 3
0000078233 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_DOWN
0000078234 [system.nm] TRACE: Interface 4 power state changed: DOWN
0000078235 [ncp.esp32.client] TRACE: NCP connection state changed: 0
0000078236 [net.esp32ncp] TRACE: NCP event 2
0000078237 [net.esp32ncp] TRACE: State changed event: 0
0000078237 [net.ifapi] INFO: Netif wl3 link DOWN, profile=NONE
0000078238 [hal] INFO: DNS server list changed
0000078239 [hal] INFO: DNS server list changed
0000078243 [system.nm] INFO: State changed: IFACE_LINK_UP -> IFACE_UP
0000078243 [ncp.esp32.client] TRACE: NCP state changed: 0
0000078244 [net.esp32ncp] TRACE: NCP event 1
0000078245 [ncp.esp32.client] TRACE: Deinit modem serial.
0000078345 [net.esp32ncp] TRACE: NCP event 3
0000078346 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
0000078347 [system.nm] TRACE: Interface 4 power state changed: POWERING_UP
0000079648 [ncp.esp32.at] TRACE: > AT
0000079650 [ncp.esp32.at] TRACE: < OK
0000080650 [ncp.esp32.client] TRACE: NCP ready to accept AT commands
0000080651 [ncp.esp32.at] TRACE: > AT+MVER
0000080652 [ncp.esp32.at] TRACE: < 3
0000080653 [ncp.esp32.at] TRACE: < OK
0000080654 [ncp.esp32.at] TRACE: > AT+GETMAC=0
0000080655 [ncp.esp32.at] TRACE: < +GETMAC: "30:ae:a4:d1:78:10"
0000080656 [ncp.esp32.at] TRACE: < OK
0000080658 [ncp.esp32.at] TRACE: > AT+CWDHCP=0,3
0000080661 [ncp.esp32.at] TRACE: < OK
0000080662 [ncp.esp32.client] TRACE: NCP state changed: 1
0000080663 [net.esp32ncp] TRACE: NCP event 1
0000080663 [net.esp32ncp] TRACE: NCP event 3
0000080664 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_UP
0000080665 [system.nm] TRACE: Interface 4 power state changed: UP
0000080669 [ncp.esp32.at] TRACE: > AT+CWLAP
