Cannot connect Argon to Cloud: Failed to write into data channel -60001
Hello,
I have problems connecting my Argon to the cloud.
See below the output from the particle cloud debug tool running on 3.0.0.
What I have tried so far:
  1. Revert to 1.5.2
  2. Flash tinker
  3. Particle update
Serial monitor opened successfully:
> 0000015281 [app] INFO: Starting Tests!
0000015281 [app] INFO: Platform: Argon
0000015281 [app] INFO: Binary compiled for: 2.1.0
0000015282 [app] INFO: Cloud Debug Release 2.1.4
0000015282 [app] INFO: System version: 3.0.0
0000015283 [app] INFO: Device ID: e00fce6878922********
0000015283 [app] INFO: USB power: true, Battery Volage: 4.20
0000015284 [app] INFO: This device could have Ethernet (is 3rd generation)
0000015285 [app] INFO: FEATURE_ETHERNET_DETECTION not enabled, so Ethernet will not be used (even i
0000015296 [app] INFO: Configured credentials:
0000015299 [app] INFO:   ssid=Ping of the North security=wpa2 cipher=AES or TKIP
0000015299 [app] INFO: Available access points:
0000015300 [ncp.esp32.at] TRACE: > AT+CWLAP
0000017804 [ncp.esp32.at] TRACE: < +CWLAP:(0,"",-38,"fa:8f:ca:87:0b:23",1)
0000017804 [app] INFO:   ssid= security=unsecured channel=1 rssi=-38
0000017805 [ncp.esp32.at] TRACE: < +CWLAP:(3,"Ping of the North",-51,"f0:b0:14:29:66:c0",1)
0000017806 [app] INFO:   ssid=Ping of the North security=wpa2 channel=1 rssi=-51
0000017806 [ncp.esp32.at] TRACE: < OK
0000017806 [app] INFO: Connecting to Wi-Fi
0000017818 [system.nm] INFO: State changed: IFACE_DOWN -> IFACE_REQUEST_UP
0000017824 [net.ifapi] INFO: Netif wl3 state UP
0000017826 [system.nm] INFO: State changed: IFACE_REQUEST_UP -> IFACE_UP
0000017830 [ncp.esp32.at] TRACE: > AT+CWLAP
0000020334 [ncp.esp32.at] TRACE: < +CWLAP:(0,"",-41,"fa:8f:ca:87:0b:23",1)
0000020334 [ncp.esp32.at] TRACE: < +CWLAP:(3,"Ping of the North",-53,"f0:b0:14:29:66:c0",1)
0000020335 [ncp.esp32.at] TRACE: < OK
0000020335 [ncp.esp32.client] TRACE: Connecting to "Ping of the North"
0000023342 [ncp.esp32.at] TRACE: < WIFI CONNECTED
0000024172 [ncp.esp32.at] TRACE: < OK
0000024172 [ncp.esp32.client] TRACE: NCP connection state changed: 2
0000024173 [net.esp32ncp] TRACE: NCP event 2
0000024173 [net.esp32ncp] TRACE: State changed event: 2
0000024174 [ncp.esp32.client] ERROR: Failed to write into data channel -60001
0000024174 [net.ifapi] INFO: Netif wl3 link UP
0000024174 [system.nm] INFO: State changed: IFACE_UP -> IFACE_LINK_UP
0000024175 [net.esp32ncp] TRACE: NCP event 3
0000024175 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_DOWN
0000024176 [system.nm] TRACE: Interface 4 power state changed: 3
0000024176 [net.esp32ncp] TRACE: NCP event 3
0000024177 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_DOWN
0000024177 [system.nm] TRACE: Interface 4 power state changed: 1
0000024177 [ncp.esp32.client] TRACE: NCP connection state changed: 0
0000024178 [net.esp32ncp] TRACE: NCP event 2
0000024178 [net.esp32ncp] TRACE: State changed event: 0
0000024178 [net.ifapi] INFO: Netif wl3 link DOWN
0000024181 [system.nm] INFO: State changed: IFACE_LINK_UP -> IFACE_UP
0000024181 [ncp.esp32.client] TRACE: NCP state changed: 0
0000024182 [net.esp32ncp] TRACE: NCP event 1
0000024182 [ncp.esp32.client] TRACE: Deinit modem serial.
0000024282 [net.esp32ncp] TRACE: NCP event 3
0000024282 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
0000024282 [system.nm] TRACE: Interface 4 power state changed: 4
0000025583 [ncp.esp32.at] TRACE: > AT
0000025584 [ncp.esp32.at] TRACE: < OK
0000026584 [ncp.esp32.client] TRACE: NCP ready to accept AT commands
0000026584 [ncp.esp32.at] TRACE: > AT+MVER
0000026585 [ncp.esp32.at] TRACE: < 3
0000026586 [ncp.esp32.at] TRACE: < OK
0000026586 [ncp.esp32.at] TRACE: > AT+CWDHCP=0,3
0000026589 [ncp.esp32.at] TRACE: < OK
0000026589 [ncp.esp32.client] TRACE: NCP state changed: 1
0000026590 [net.esp32ncp] TRACE: NCP event 1
0000026590 [net.esp32ncp] TRACE: NCP event 3
0000026590 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_UP
0000026591 [system.nm] TRACE: Interface 4 power state changed: 2
0000026593 [ncp.esp32.at] TRACE: > AT+CWLAP
0000027807 [app] INFO: Still trying to connect to Wi-Fi 00:10
0000029097 [ncp.esp32.at] TRACE: < +CWLAP:(0,"",-39,"fa:8f:ca:87:0b:23",1)
0000029098 [ncp.esp32.at] TRACE: < +CWLAP:(3,"Ping of the North",-53,"f0:b0:14:29:66:c0",1)
0000029098 [ncp.esp32.at] TRACE: < +CWLAP:(3,"",-88,"82:2a:a8:c4:6e:b7",6)
0000029099 [ncp.esp32.at] TRACE: < +CWLAP:(3,"Ping of the North",-88,"80:2a:a8:c4:6e:b7",6)
0000029100 [ncp.esp32.at] TRACE: < +CWLAP:(3,"Ziggo3E6B2DA",-91,"90:5c:44:45:ff:6c",6)
0000029101 [ncp.esp32.at] TRACE: < +CWLAP:(5,"Ziggo",-91,"92:5c:14:45:ff:6c",6)
0000029101 [ncp.esp32.at] TRACE: < +CWLAP:(3,"ZiggoCE775C6",-94,"54:67:51:0c:31:03",11)
0000029102 [ncp.esp32.at] TRACE: < +CWLAP:(5,"Ziggo",-94,"56:67:11:0c:31:03",11)
0000029103 [ncp.esp32.at] TRACE: < OK
0000029103 [ncp.esp32.client] TRACE: Connecting to "Ping of the North"
0000032132 [ncp.esp32.at] TRACE: < WIFI CONNECTED
0000032940 [ncp.esp32.at] TRACE: < OK
0000032941 [ncp.esp32.client] TRACE: NCP connection state changed: 2
0000032941 [net.esp32ncp] TRACE: NCP event 2
0000032941 [net.esp32ncp] TRACE: State changed event: 2
0000032942 [ncp.esp32.client] ERROR: Failed to write into data channel -60001
0000032942 [net.ifapi] INFO: Netif wl3 link UP
0000032943 [system.nm] INFO: State changed: IFACE_UP -> IFACE_LINK_UP
0000032944 [net.esp32ncp] TRACE: NCP event 3
0000032944 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_DOWN
0000032944 [system.nm] TRACE: Interface 4 power state changed: 3
0000032945 [net.esp32ncp] TRACE: NCP event 3
0000032945 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_DOWN
0000032945 [system.nm] TRACE: Interface 4 power state changed: 1
0000032946 [ncp.esp32.client] TRACE: NCP connection state changed: 0
0000032946 [net.esp32ncp] TRACE: NCP event 2
0000032946 [net.esp32ncp] TRACE: State changed event: 0
0000032947 [net.ifapi] INFO: Netif wl3 link DOWN
0000032949 [system.nm] INFO: State changed: IFACE_LINK_UP -> IFACE_UP
0000032950 [ncp.esp32.client] TRACE: NCP state changed: 0
0000032950 [net.esp32ncp] TRACE: NCP event 1
0000032950 [ncp.esp32.client] TRACE: Deinit modem serial.
0000033051 [net.esp32ncp] TRACE: NCP event 3
0000033051 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
0000033051 [system.nm] TRACE: Interface 4 power state changed: 4
0000034352 [ncp.esp32.at] TRACE: > AT
0000034353 [ncp.esp32.at] TRACE: < OK
0000035353 [ncp.esp32.client] TRACE: NCP ready to accept AT commands
0000035353 [ncp.esp32.at] TRACE: > AT+MVER
0000035354 [ncp.esp32.at] TRACE: < 3
0000035355 [ncp.esp32.at] TRACE: < OK
0000035355 [ncp.esp32.at] TRACE: > AT+CWDHCP=0,3
0000035358 [ncp.esp32.at] TRACE: < OK
0000035358 [ncp.esp32.client] TRACE: NCP state changed: 1
0000035359 [net.esp32ncp] TRACE: NCP event 1
0000035359 [net.esp32ncp] TRACE: NCP event 3
0000035359 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_UP
0000035360 [system.nm] TRACE: Interface 4 power state changed: 2
0000035362 [ncp.esp32.at] TRACE: > AT+CWLAP
0000037807 [app] INFO: Still trying to connect to Wi-Fi 00:20
0000037866 [ncp.esp32.at] TRACE: < +CWLAP:(0,"",-39,"fa:8f:ca:87:0b:23",1)
0000037867 [ncp.esp32.at] TRACE: < +CWLAP:(3,"Ping of the North",-53,"f0:b0:14:29:66:c0",1)
0000037867 [ncp.esp32.at] TRACE: < +CWLAP:(5,"Ziggo",-91,"92:5c:14:45:ff:6c",6)
0000037868 [ncp.esp32.at] TRACE: < OK
0000037868 [ncp.esp32.client] TRACE: Connecting to "Ping of the North"
0000040876 [ncp.esp32.at] TRACE: < WIFI CONNECTED
0000041705 [ncp.esp32.at] TRACE: < OK
0000041706 [ncp.esp32.client] TRACE: NCP connection state changed: 2
0000041706 [net.esp32ncp] TRACE: NCP event 2
0000041706 [net.esp32ncp] TRACE: State changed event: 2
0000041707 [ncp.esp32.client] ERROR: Failed to write into data channel -60001
0000041707 [net.ifapi] INFO: Netif wl3 link UP
0000041708 [system.nm] INFO: State changed: IFACE_UP -> IFACE_LINK_UP
0000041708 [net.esp32ncp] TRACE: NCP event 3
0000041709 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_DOWN
0000041709 [system.nm] TRACE: Interface 4 power state changed: 3
0000041710 [net.esp32ncp] TRACE: NCP event 3
0000041710 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_DOWN
0000041710 [system.nm] TRACE: Interface 4 power state changed: 1
0000041711 [ncp.esp32.client] TRACE: NCP connection state changed: 0
0000041711 [net.esp32ncp] TRACE: NCP event 2
0000041711 [net.esp32ncp] TRACE: State changed event: 0
0000041712 [net.ifapi] INFO: Netif wl3 link DOWN
0000041714 [system.nm] INFO: State changed: IFACE_LINK_UP -> IFACE_UP
0000041715 [ncp.esp32.client] TRACE: NCP state changed: 0
0000041715 [net.esp32ncp] TRACE: NCP event 1
0000041715 [ncp.esp32.client] TRACE: Deinit modem serial.
0000041816 [net.esp32ncp] TRACE: NCP event 3
0000041816 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
0000041816 [system.nm] TRACE: Interface 4 power state changed: 4
0000043117 [ncp.esp32.at] TRACE: > AT
0000043118 [ncp.esp32.at] TRACE: < OK
0000044118 [ncp.esp32.client] TRACE: NCP ready to accept AT commands
0000044118 [ncp.esp32.at] TRACE: > AT+MVER
0000044119 [ncp.esp32.at] TRACE: < 3
0000044120 [ncp.esp32.at] TRACE: < OK
0000044120 [ncp.esp32.at] TRACE: > AT+CWDHCP=0,3
0000044123 [ncp.esp32.at] TRACE: < OK
0000044123 [ncp.esp32.client] TRACE: NCP state changed: 1
0000044124 [net.esp32ncp] TRACE: NCP event 1
0000044124 [net.esp32ncp] TRACE: NCP event 3
0000044124 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_UP
0000044125 [system.nm] TRACE: Interface 4 power state changed: 2
0000044127 [ncp.esp32.at] TRACE: > AT+CWLAP
0000046631 [ncp.esp32.at] TRACE: < +CWLAP:(0,"",-38,"fa:8f:ca:87:0b:23",1)
0000046632 [ncp.esp32.at] TRACE: < +CWLAP:(3,"Ping of the North",-51,"f0:b0:14:29:66:c0",1)
0000046632 [ncp.esp32.at] TRACE: < OK
0000046633 [ncp.esp32.client] TRACE: Connecting to "Ping of the North"
0000047807 [app] INFO: Still trying to connect to Wi-Fi 00:30
0000049754 [ncp.esp32.at] TRACE: < WIFI CONNECTED
0000050489 [ncp.esp32.at] TRACE: < OK
0000050490 [ncp.esp32.client] TRACE: NCP connection state changed: 2
0000050490 [net.esp32ncp] TRACE: NCP event 2
0000050490 [net.esp32ncp] TRACE: State changed event: 2
0000050491 [ncp.esp32.client] ERROR: Failed to write into data channel -60001
0000050491 [net.ifapi] INFO: Netif wl3 link UP
0000050492 [system.nm] INFO: State changed: IFACE_UP -> IFACE_LINK_UP
0000050492 [net.esp32ncp] TRACE: NCP event 3
0000050493 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_DOWN
0000050493 [system.nm] TRACE: Interface 4 power state changed: 3
0000050494 [net.esp32ncp] TRACE: NCP event 3
0000050494 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_DOWN
0000050494 [system.nm] TRACE: Interface 4 power state changed: 1
0000050495 [ncp.esp32.client] TRACE: NCP connection state changed: 0
0000050495 [net.esp32ncp] TRACE: NCP event 2
0000050495 [net.esp32ncp] TRACE: State changed event: 0
0000050496 [net.ifapi] INFO: Netif wl3 link DOWN
0000050498 [system.nm] INFO: State changed: IFACE_LINK_UP -> IFACE_UP
0000050499 [ncp.esp32.client] TRACE: NCP state changed: 0
0000050499 [net.esp32ncp] TRACE: NCP event 1
0000050499 [ncp.esp32.client] TRACE: Deinit modem serial.
0000050600 [net.esp32ncp] TRACE: NCP event 3
0000050600 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
0000050600 [system.nm] TRACE: Interface 4 power state changed: 4
0000051901 [ncp.esp32.at] TRACE: > AT
0000051902 [ncp.esp32.at] TRACE: < OK
0000052902 [ncp.esp32.client] TRACE: NCP ready to accept AT commands
0000052902 [ncp.esp32.at] TRACE: > AT+MVER
0000052903 [ncp.esp32.at] TRACE: < 3
0000052904 [ncp.esp32.at] TRACE: < OK
0000052904 [ncp.esp32.at] TRACE: > AT+CWDHCP=0,3
0000052907 [ncp.esp32.at] TRACE: < OK
0000052907 [ncp.esp32.client] TRACE: NCP state changed: 1
0000052908 [net.esp32ncp] TRACE: NCP event 1
0000052908 [net.esp32ncp] TRACE: NCP event 3
0000052908 [net.esp32ncp] TRACE: NCP power state changed: IF_POWER_STATE_UP
0000052909 [system.nm] TRACE: Interface 4 power state changed: 2
0000052911 [ncp.esp32.at] TRACE: > AT+CWLAP
0000055415 [ncp.esp32.at] TRACE: < +CWLAP:(3,"Ping of the North",-51,"f0:b0:14:29:66:c0",1)
0000055416 [ncp.esp32.at] TRACE: < +CWLAP:(3,"Ping of the North",-88,"80:2a:a8:c4:6e:b7",6)
0000055417 [ncp.esp32.at] TRACE: < +CWLAP:(3,"",-88,"82:2a:a8:c4:6e:b7",6)
0000055417 [ncp.esp32.at] TRACE: < OK
0000055418 [ncp.esp32.client] TRACE: Connecting to "Ping of the North"
@marekparticle last time you helped me out pretty good. Could you shed some light on what I am experiencing?
