After an OTA my argon is stuck solid white. It will not enter listening mode.
I have tried reflashing the firmware it has not worked.
Once in DFU mode the yellow light flashes quickly. During the file transfer it flashed slower. After DFU says it flashed successful it flashes Yellow faster (as if put back into DFU mode). It never stops flashing yellow. In fact you can just keep sending the firmware and it will keep flashing yellow. If I hit reset it goes back to sold white.
$particle flash -v --usb hybrid-0.8.0-rc.27-argon.bin
dfu-util 0.9
Deducing device DFU version from functional descriptor length
ID 2b04:d00c
Claiming USB DFU Interface...
dfuIDLE, continuing
Downloading to address = 0x00030000, size = 646044
Download [=========================] 100% 646044 bytes
Download done.
File downloaded successfully
Flash success!
