I have seen another post about this for the Boron. On that post @rickkas7 replied this isn’t really an error and it will get over it. However, I am using PublishQueueAsyncRK library and once this happens the device does not publish anymore and isn’t responding to function calls but does for variable gets. The device is breathing cyan. Only hard reset works. Any ideas?
The log output is
0000979624 [app.pubq] INFO: published successfully
0008458298 [comm.protocol] ERROR: Event loop error 3
0008462205 [system] ERROR: Failed to load session data from persistent storage
Device OS is 1.4.4, the publish queue is being held in FRAM is this helps understand.
