Boron showing [system] ERROR: Failed to load session data from persistent storage
I have some devices running at a customer site with borons and papertrail to see log messages. I often see blocks like this:
What do these errors mean?
Until now, I just ignored them. But today I had a device on my test bench showing a problem similar to something the customer reported and I assume a connection:
The Boron was blinking cyan, which means internet, but no particle cloud. Waiting a long time (~15min), this did not change. After a reboot, the connection could be established normally. The error message was again [system] ERROR: Failed to load session data from persistent storage.
But additional to the connection problem, the main loop was not working anymore. It should send some data over uart in intervalls, this stopped. I use SYSTEM_THREAD(ENABLED);, so the main loop should run even with connection problems. I do not use any particle cloud functions or publish.
I am using a third party sim, I had no problems with this provider on Electrons. This is our first Boron project.
Can anyone help me with these error messages? Thank you in advance!
That is not really an error. I'm not sure why it's set at error level, actually. There are many reasons a Gen 3 device won't be able to retrieve its session information from persistent storage, and if that happens it will just renegotiate.
ERROR: Failed to determine server address
Now that actually is an error. It means that the device can't determine the cloud server address. Either there's a DNS problem, or there's a problem with the server address setting.
You could try a particle key server in DFU mode (blinking yellow) to reset it.
Or you can get Boron cloud debug log which will show in much greater detail what actually is failing:
Thank you for the hints. I think there should be no problem with the server address as the connection is always established after a boot from power off and the errors only come after the device is running for some minutes.
At the moment I am not sure about the relation of my application to the problem, although I am not using any Particle cloud features, it’s just there for OTA updates. I will investigate this, use your clouddebug tool and come back with more information about the problem.
Occasionally I get this issue with the b-som continually blinking green. Usually it will either fix itself after about 10 minutes or full power off. Any suggestion on preventing this issue?
0000006044 [system] INFO: Cloud socket connected
0000006044 [comm.protocol.handshake] INFO: Establish secure connection
0000006046 [comm.dtls] INFO: session has 0 uses
0000006054 [comm.dtls] INFO: (CMPL,RENEG,NO_SESS,ERR) restoreStatus=0
0000006054 [comm.dtls] INFO: out_ctr 0,1,0,0,0,0,0,18, next_coap_id=d
0000006054 [comm.dtls] INFO: restored session from persisted session data. next_msg_id=13
0000006055 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 2
0000006310 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 4
0000006310 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 3
0000006310 [comm.protocol.handshake] INFO: Sending HELLO message
0000080888 [comm.coap] ERROR: CoAP message timeout; ID: 14
0000080888 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 0
0000080888 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 4
0000080889 [comm.protocol.handshake] ERROR: Could not send HELLO message: 10
0000088190 [system.cm] ERROR: No addrinfo for e00fce68faa0dac1315478e5.v5.udp-mesh.particle.io#5684
0000088191 [system] WARN: Internet test failed: -230 network
0000088191 [system] WARN: Cloud handshake failed, code=-160
0000088441 [system] INFO: Cloud: disconnecting
0000088441 [system] INFO: Cloud: disconnected
0000088441 [system] INFO: Cloud: connecting
0000088445 [system] WARN: Failed to load session data from persistent storage
0000096190 [system] ERROR: Failed to determine server address
0000096191 [system] WARN: Cloud socket connection failed: -230
0000104190 [system.cm] ERROR: No addrinfo for **********************.v5.udp-mesh.particle.io#5684
0000104191 [system] WARN: Internet test failed: -230 network
0000104191 [system] WARN: Handling cloud error: 2
0000104191 [system] INFO: Cloud: connecting
0000104195 [system] WARN: Failed to load session data from persistent storage
0000112190 [system] ERROR: Failed to determine server address
0000112191 [system] WARN: Cloud socket connection failed: -230
0000120190 [system.cm] ERROR: No addrinfo for **********************.v5.udp-mesh.particle.io#5684
0000120191 [system] WARN: Internet test failed: -230 network
0000120191 [system] WARN: Handling cloud error: 2
0000120191 [system] INFO: Cloud: connecting
0000120195 [system] WARN: Failed to load session data from persistent storage
0000128190 [system] ERROR: Failed to determine server address
0000128191 [system] WARN: Cloud socket connection failed: -230
0000136190 [system.cm] ERROR: No addrinfo for **********************.v5.udp-mesh.particle.io#5684
0000136191 [system] WARN: Internet test failed: -230 network
0000136191 [system] WARN: Handling cloud error: 2
0000136191 [system] INFO: Cloud: connecting
0000136195 [system] WARN: Failed to load session data from persistent storage
More logs with successful connection at the end.
Thinking "Resetting network interfaces" is fixing the issue.
0001647225 [system] WARN: Handling cloud error: 2
0001647325 [system] INFO: Cloud: connecting
0001647327 [system] WARN: Failed to load session data from persistent storage
0001655225 [system] ERROR: Failed to determine server address
0001655225 [system] WARN: Cloud socket connection failed: -230
0001663225 [system.cm] ERROR: No addrinfo for ************************.v5.udp-mesh.particle.io#5684
0001663225 [system] WARN: Internet test failed: -230 network
0001663225 [system] WARN: Handling cloud error: 2
0001663325 [system] INFO: Cloud: connecting
0001663327 [system] WARN: Failed to load session data from persistent storage
0001671225 [system] ERROR: Failed to determine server address
0001671225 [system] WARN: Cloud socket connection failed: -230
0001679225 [system.cm] ERROR: No addrinfo for ************************.v5.udp-mesh.particle.io#5684
0001679225 [system] WARN: Internet test failed: -230 network
0001679225 [system] WARN: Handling cloud error: 2
0001679325 [system] INFO: Cloud: connecting
0001679327 [system] WARN: Failed to load session data from persistent storage
0001687225 [system] ERROR: Failed to determine server address
0001687225 [system] WARN: Cloud socket connection failed: -230
0001695225 [system.cm] ERROR: No addrinfo for ************************.v5.udp-mesh.particle.io#5684
0001695225 [system] WARN: Internet test failed: -230 network
0001695225 [system] WARN: Handling cloud error: 2
0001695325 [system] INFO: Cloud: connecting
0001695327 [system] WARN: Failed to load session data from persistent storage
0001703225 [system] ERROR: Failed to determine server address
0001703225 [system] WARN: Cloud socket connection failed: -230
0001711225 [system.cm] ERROR: No addrinfo for ************************.v5.udp-mesh.particle.io#5684
0001711225 [system] WARN: Internet test failed: -230 network
0001711225 [system] WARN: Handling cloud error: 2
0001711325 [system] INFO: Cloud: connecting
0001711327 [system] WARN: Failed to load session data from persistent storage
0001719225 [system] ERROR: Failed to determine server address
0001719225 [system] WARN: Cloud socket connection failed: -230
0001727225 [system.cm] ERROR: No addrinfo for ************************.v5.udp-mesh.particle.io#5684
0001727225 [system] WARN: Internet test failed: -230 network
0001727225 [system] WARN: Handling cloud error: 2
0001727325 [system] INFO: Cloud: connecting
0001727327 [system] WARN: Failed to load session data from persistent storage
0001735225 [system] ERROR: Failed to determine server address
0001735225 [system] WARN: Cloud socket connection failed: -230
0001743225 [system.cm] ERROR: No addrinfo for ************************.v5.udp-mesh.particle.io#5684
0001743225 [system] WARN: Internet test failed: -230 network
0001743225 [system] WARN: Handling cloud error: 2
0001743325 [system] INFO: Cloud: connecting
0001743327 [system] WARN: Failed to load session data from persistent storage
0001751225 [system] ERROR: Failed to determine server address
0001751225 [system] WARN: Cloud socket connection failed: -230
0001759225 [system.cm] ERROR: No addrinfo for ************************.v5.udp-mesh.particle.io#5684
0001759225 [system] WARN: Internet test failed: -230 network
0001759225 [system] WARN: Handling cloud error: 2
0001759325 [system] INFO: Cloud: connecting
0001759327 [system] WARN: Failed to load session data from persistent storage
0001767225 [system] ERROR: Failed to determine server address
0001767225 [system] WARN: Cloud socket connection failed: -230
0001775225 [system.cm] ERROR: No addrinfo for ************************.v5.udp-mesh.particle.io#5684
0001775225 [system] WARN: Internet test failed: -230 network
0001775225 [system] WARN: Handling cloud error: 2
0001775325 [system] INFO: Cloud: connecting
0001775327 [system] WARN: Failed to load session data from persistent storage
0001783225 [system] ERROR: Failed to determine server address
0001783225 [system] WARN: Cloud socket connection failed: -230
0001791225 [system.cm] ERROR: No addrinfo for ************************.v5.udp-mesh.particle.io#5684
0001791225 [system] WARN: Internet test failed: -230 network
0001791225 [system] WARN: Handling cloud error: 2
0001791325 [system] INFO: Cloud: connecting
0001791327 [system] WARN: Failed to load session data from persistent storage
0001799225 [system] ERROR: Failed to determine server address
0001799225 [system] WARN: Cloud socket connection failed: -230
0001807225 [system.cm] ERROR: No addrinfo for ************************.v5.udp-mesh.particle.io#5684
0001807225 [system] WARN: Internet test failed: -230 network
0001807225 [system] WARN: Handling cloud error: 2
0001807225 [system] INFO: Cloud: connecting
0001807229 [system] WARN: Failed to load session data from persistent storage
0001815225 [system] ERROR: Failed to determine server address
0001815225 [system] WARN: Cloud socket connection failed: -230
0001823225 [system.cm] ERROR: No addrinfo for ************************.v5.udp-mesh.particle.io#5684
0001823225 [system] WARN: Internet test failed: -230 network
0001823225 [system] WARN: Handling cloud error: 2
0001823225 [system] INFO: Cloud: connecting
0001823229 [system] WARN: Failed to load session data from persistent storage
0001831225 [system] ERROR: Failed to determine server address
0001831225 [system] WARN: Cloud socket connection failed: -230
0001839225 [system.cm] ERROR: No addrinfo for ************************.v5.udp-mesh.particle.io#5684
0001839225 [system] WARN: Internet test failed: -230 network
0001839225 [system] WARN: Handling cloud error: 2
0001839325 [system] INFO: Cloud: connecting
0001839327 [system] WARN: Failed to load session data from persistent storage
0001847225 [system] ERROR: Failed to determine server address
0001847225 [system] WARN: Cloud socket connection failed: -230
0001855225 [system.cm] ERROR: No addrinfo for ************************.v5.udp-mesh.particle.io#5684
0001855225 [system] WARN: Internet test failed: -230 network
0001855225 [system] WARN: Handling cloud error: 2
0001855325 [system] INFO: Cloud: connecting
0001855327 [system] WARN: Failed to load session data from persistent storage
0001863225 [system] ERROR: Failed to determine server address
0001863225 [system] WARN: Cloud socket connection failed: -230
0001871225 [system.cm] ERROR: No addrinfo for ************************.v5.udp-mesh.particle.io#5684
0001871225 [system] WARN: Internet test failed: -230 network
0001871225 [system] WARN: Handling cloud error: 2
0001871325 [system] INFO: Cloud: connecting
0001871327 [system] WARN: Failed to load session data from persistent storage
0001879225 [system] ERROR: Failed to determine server address
0001879225 [system] WARN: Cloud socket connection failed: -230
0001887225 [system.cm] ERROR: No addrinfo for ************************.v5.udp-mesh.particle.io#5684
0001887225 [system] WARN: Internet test failed: -230 network
0001887225 [system] WARN: Handling cloud error: 2
0001887325 [system] INFO: Cloud: connecting
0001887327 [system] WARN: Failed to load session data from persistent storage
0001895225 [system] ERROR: Failed to determine server address
0001895225 [system] WARN: Cloud socket connection failed: -230
0001903225 [system.cm] ERROR: No addrinfo for ************************.v5.udp-mesh.particle.io#5684
0001903225 [system] WARN: Internet test failed: -230 network
0001903225 [system] WARN: Handling cloud error: 2
0001903325 [system] INFO: Cloud: connecting
0001903327 [system] WARN: Failed to load session data from persistent storage
0001911225 [system] ERROR: Failed to determine server address
0001911225 [system] WARN: Cloud socket connection failed: -230
0001919225 [system.cm] ERROR: No addrinfo for ************************.v5.udp-mesh.particle.io#5684
0001919225 [system] WARN: Internet test failed: -230 network
0001919225 [system] WARN: Handling cloud error: 2
0001919325 [system] INFO: Cloud: connecting
0001919327 [system] WARN: Failed to load session data from persistent storage
0001927225 [system] ERROR: Failed to determine server address
0001927225 [system] WARN: Cloud socket connection failed: -230
0001927225 [system] WARN: Resetting network interfaces due to failed connection attempts for 5 minutes
0001927325 [system.nm] INFO: State changed: IP_CONFIGURED -> IFACE_REQUEST_DOWN
0001927326 [system.nm] INFO: State changed: IFACE_REQUEST_DOWN -> IFACE_DOWN
0001927332 [net.pppncp] ERROR: PPP error event data=5
0001927336 [system.nm] INFO: State changed: IFACE_DOWN -> DISABLED
0001927338 [system.nm] INFO: State changed: DISABLED -> IFACE_DOWN
0001927338 [system.nm] INFO: State changed: IFACE_DOWN -> IFACE_REQUEST_UP
0001927339 [system.nm] INFO: State changed: IFACE_REQUEST_UP -> IFACE_UP
0001954444 [mux] INFO: Mux channel 2 already opened
0001955549 [system.nm] INFO: State changed: IFACE_UP -> IFACE_LINK_UP
0001955551 [system.nm] INFO: State changed: IFACE_LINK_UP -> IP_CONFIGURED
0001955552 [system] INFO: Cloud: connecting
0001955556 [system] WARN: Failed to load session data from persistent storage
0001955940 [system] INFO: Cloud socket connected
0001955940 [comm.protocol.handshake] INFO: Establish secure connection
0001955946 [comm.dtls] INFO: (CMPL,RENEG,NO_SESS,ERR) restoreStatus=2
0001957360 [comm.protocol.handshake] INFO: Sending HELLO message
0001957666 [comm.protocol.handshake] INFO: Handshake completed
0001957666 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 4
0001957668 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 3
0001958133 [comm.protocol] INFO: Sending subscriptions
0001958481 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 4
0001958934 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 3
0001959036 [comm.protocol] INFO: Received TIME response: 1714581404
0001959236 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 4
0001959236 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 3
0001960073 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 4
0001960073 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 3
0001960177 [system] INFO: Cloud connected
0001960177 [comm.protocol] INFO: Received DESCRIBE request; flags: 0x04
This is not really an error, it will happen frequently including on cold boot.
This is not normal. It means the DNS request to look up the cloud address failed. This could happen if there was poor cellular connectivity. If something happened and the modem was in a bad state somehow, resetting the network interface would probably resolve it. It could also be a cellular network data issue, which would likely resolve itself.
