I want to power my argon (“argn-h”; does h mean headless here?) from a power supply which has a voltage between 5V and 5.5V (officially it is 5V, but this depends in reality on the load). Is it possible to power the argon safely with this supply? The data sheet just says “5V”, there is no range. Which power interface would be best? I had though about using the USB power connection.
Thank you very much!
